+ Reply to Thread
Results 1 to 12 of 12
Thread: Interior Dome Lights
    VY Equipe S2
    Mar 2009
    Default Interior Dome Lights
    Hey all,
    Im just wondering what size is the bayonet style lights in the VY dome lights? Because i want to get x2 red leds to bright up the dome lights as in the back 2 passenger door lights, the festoon 36mm lights are a nice led red so i would like to apply it to the whole car. If anyone has a link of where to find some i'd be ever appreciative.
    Thanks,
    Marlon
    VY Equipe S2
    Mar 2009
    VS Equipe
    May 2009
    VYMAD's Avatar
    VYMAD is online now SILVERFOX VYMAD Calais
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Do you find that they are as bright as the standard globes were?
    VYII Equipe S/wagon V6
    May 2009
    Melb, Vic
    If you wore night vision goggles :P
    I hardly doubt they'd be brighter due to the light spectrum
    Cheers,
    Dave
    vz exec
    Jan 2009
    awesome work dude
    can you tell me exactly where you got the dome lights from?
    i want to get some blue ones for myself!
    the ones i have bought do not work for some reason.
    VY Equipe S2
    Mar 2009
    Quote Originally Posted by park0 View Post
    awesome work dude
    Hey,
    Umm with the lights what sort of lighting system do you have?
    If you have the sunnies holder like me the globes are called bayonets. With the bayonets they are quite hard to find, even on ebay. So what i did was i bought a kit and wrapped red cellafane around it, however you spell it. See if you put blue cella around your normal bayonet it will burn through it and could cause a melt or fire hazard. So buy a led kit like this and then wrap blue cella around the led kit in the lighting system
    1pc BA9S 1895 T4W Bayonet 12 High Power LED (White) PCB - eBay LED, Lights, Indicators, Car Parts, Accessories, Cars, Bikes, Boats. (end time 01-Jul-09 13:10:32 AEST).
    So see the first big SMD chip? That's what i have in my sunny holder, but 2 of them, one on each side.
    I bought something like this off ebay
    2 x Blue LED Side Light Bulbs T4W Bayonet BA9S 24V - eBay Other Lights, Indicators, Lights, Indicators, Car Parts, Accessories, Cars, Bikes, Boats. (end time 26-Jun-09 20:24:37 AEST)
    and these didn't fit in yet they were the same size, i don't know why but this is how i did my lights.
    Also you may need to reverse polarity, that means you may need to de-solder the wires and re-solder the green and red wires. If so ill take a photo to show you how my wires are on top of the sunny holder.
    But some Holdens have the lighting kit in the middle of the cabin, above the console lid. Those lights are a festoon base. I think they are either 36mm or 42mm off the top of my head. Then go on ebay and type in "blue festoon" and that will give you some festoon globes to fit your light.
    One more thing whilst im here, if you do have the sunny holder thing at the front you will have rear side lights above your passenger doors, they are 36mm festoons.
    Hope that helps mate, if not ill take out my sunny holder and show you the wiring kit above the sunny holder. The only problem about these led kits are the wires though, if you see the bayonet light in this
    you need to put that into your bayonet base holder and then if you can see the little wire that comes off it with a little plug, you then need to plug the big SMD led to that bayonet wire which then makes the LED work. Also don't wrap too much cella around the led as this sort of holds the light in too much and then wont bright up the cabin too much. So wrap the cella around the led about 2-3 layers or until you have your desired result.
    Good luck, any questions just ask me.
    vz exec
    Jan 2009
    My commodore has the lights in the sunglass holder like yours does.
    i have the t4w/ba9s/bayonet LEDS that 'fit but don't work'
    So i think 'reversing the polarity' is the next step!
    VY Equipe S2
    Mar 2009
    I wonder if reversing the polarity is just the problem?
    Maybe because they are LED's?
    Anyway mate i have my car back in a few days so ill take a photo for you so you can reverse your wires, you will need to solder an extender wire onto i think the green wire because it will not reach the otherside, you'll see what i mean when i post the picture up in the next few days.
    VY Equipe S2
    Mar 2009
    Quote Originally Posted by VYMAD View Post
    They are not as bright as blue or white but they give an awsome look. That's why it's also good to have some other lights in your car, led footwells and other lights which can brighten up the cabin help alot.
    VZ Executive
    Nov 2010
    i went to autobarn and got some LED lights for my dome in my VZ but they wouldnt work for some reason, does anyone know where i can get the bayonet globes from? Or if i wrap blue cella around my normal globes will they shine blue?
    VKCOMMO's Avatar
    VKCOMMO is online now Carpark Mechanic..... VKCOMMO Caprice
    Aug 2009
    Springwood, NSW
    Yeah man, LED globes are positive negative sensitive, Just flip it around and should work
    [09-01, 22:47] HoZy: VKC doesnt finger, He fists... Because Ranga
+ Reply to Thread
  1. dome nuts....can't find any!!
    By DANNY8 in forum The Pub
    Last Post: 11-01-2008, 08:19 PM
  2. installing sle dome light into slx
    By oldmatevh in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 10-05-2007, 04:22 PM
  3. No interior lights, dash lights or elec windows vk
    By ported in forum Electrical Wiring / Questions
    Last Post: 18-09-2006, 04:10 AM
  4. dome light
    By jezzaaa in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-08-2006, 08:07 AM
  5. vs exec dome light upgrade
    By AKII1R in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-10-2005, 02:54 PM
