Results 1 to 10 of 10
Thread: ECU scantool and airbag light VT commodore
    vt
    Apr 2009
    Default ECU scantool and airbag light VT commodore
    Noob question..can the diy scantool erase the airbag light? if not what can?
    Thanks Johnno
    vt
    Apr 2009
    Talking Iv'e anwered my on question..
    Thanks for all the replies but..doin' a search revealed all.
    Too bad the DIY scantool hasn't software available to probe further into the 'other' areas of interest! ..(imagine a home built Tech 2?)
    Johnno
    VT spac super6
    Nov 2008
    Riverton sa
    just need to be able to access body control section..
    mine had the same thing.. was a pretensioner the whole time
    VT Commodore Berlina Ser2 Wagon
    Oct 2010
    Kallangur, Brisbane, Australia
    I just replaced the drivers side pretensioner in my 1999 VT Commodore last week at $170.00 . I had the code cleared, the light stayed off for about 4 days before re-appearing again. Anyone had similar experiences....or know what to look for??? This is turning into an expensive expedition!!!
    VT Calais S1, VK Wagon EFI 5.0L
    Jul 2005
    could be the clock spring, had exactly the same thing happen on my vt calais, ended up being the clock spring and hit the dead spot in a shopping centre car park.
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    if air bag light on you need to get the code for why then fix that circuit
    either get holden to pul;l code and replace part then return to turn off light
    OR
    go to a workshop with an (expensive) scantool as they can access all modules too
    REMEBER NEVER USE A MULTIMETER ON AN AIRBAG CIRCUIT
    VXII
    Nov 2009
    Rubbish. A multimeter of the correct type is perfectly safe to use on an SRS circuit.
    vs v6 commodore&vs v6 91 hilux 4x4
    Nov 2010
    brisbane
    the same thing happen on my vt 2 days ago i turned into a servo and when turning the wheel theb keys made a crunching sound or somthing there did and then the airbag light still dont know
    VT Berlina S1 V6
    Jan 2012
    exact same thing here, i turned into a survo and the light went on. I got a VT berlina had the code checked. - "31 - Drivers Airbag Open Circuit (Capacitance Too Low) - Something tells me it could be the clock spring.
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by svill123 View Post
    Mine also came on when turning sharply so I assumed it was the clock spring and it was but I'm sure the code I got was 21, but that doesn't mean that 31 isn't related to the clock spring also.
    MY RIDE
  1. VT commodore airbag light
    By zumanity in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-01-2010, 07:13 PM
  2. >Need help< AIRBAG LIGHT
    By DND in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-08-2009, 11:16 AM
  3. SRS Airbag light
    By The Raz in forum General
    Last Post: 05-03-2009, 11:05 PM
  4. airbag light
    By weedo_86 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-03-2006, 01:29 PM
  5. airbag light
    By VL-187 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-07-2005, 04:45 PM
