+ Reply to Thread
Results 1 to 18 of 18
Thread: Body Control Module issues?
    VZ - S
    Apr 2009
    Default Body Control Module issues?
    G'day all.
    This is my first post, so apologies if my question has been asked already.
    I'm currently driving the boss's VZ - S Ute whilst he's overseas, and am experiencing some issues with the indicators.
    This afternoon I'd noticed that the indicators both externally and upon the dash do not work at all. In fact the left and right turn signals don't actually have any typical clicking sounds coming from the flasher relay (BCM?).
    When I select the hazards, the hazard relay can be heard, however none of the indicators operate either.
    The indicators still don't flash when I lock/unlock the vehicle via the key fob, however what may be the hazard relay still makes an audible noise as expected.
    Can the problems I'm experiencing by related to the Body Control Module? I'm hoping to find a solution asap to reduce the risk of driving without indicators.
    Thanks in advance.
    Steve.
    maginoodle's Avatar
    maginoodle is offline Donating Member maginoodle Berlina
    vy series2 ss crewman
    Apr 2006
    you would be thinking of the flasher can.
    when you say that you can hear it when you have the hazards on is it clicking on and of like the blinkers are working or is it clicking on and staying on?
    heres my ride, i know its not much but its mine
    http://forums.justcommodores.com.au/...-ss-crewy.html
    and heres my new project
    http://forums.justcommodores.com.au/...ml#post1104629
    VZ - S
    Apr 2009
    Hi maginoodle, thanks for the reply.
    The clicking on/off of the flasher can sounds normal (like when the blinkers are working properly) when the hazard button is depressed only (no sound at all when using the indicator stalk) , yet no indicators (blinkers) actually work.
    I sniffed around under the dash to isolate the location of the flasher can whilst the hazard button was on, only to discover that the clicking sound comes from within a Body Control Module.
    I was hoping to find traditional flasher cans in the hope if simply replacing one, however it appears to be more complicated than first thought.
    VZ - S
    Apr 2009
    Update.
    It seems that the brake lights aren't working either!
    The headlights are working fine, as is the high beam functions.
    Any ideas gents?
    All roads seem to be pointing to the Body Control Module.
    What's the next step? Will a replacement unit sort things out? Should a new BCM be purchased with a matching key fob? By the looks of it the key itself can be screwed into a replacement fob.
    Would this be the best approach to take?
    Cheers.
    Steve.
    Last edited by Ultimate Home Theatres; 23-04-2009 at 03:50 PM. Reason: Adding more details.
    VZ - S
    Apr 2009
    Brake lights are actually working OK, so it looks like my only issues are with the indicators.
    Any further advice from anyone out there?
    lil_mickey's Avatar
    lil_mickey is offline LOUD AND PROUD lil_mickey Executive
    VH 253 :-)
    Jul 2006
    Geelong; Victoria
    Checked the fuses?
    Just my 2 cents worth...
    Quote Originally Posted by wraith View Post
    Your not cool till your car looks like a dog with worms.
    accentstencil's Avatar
    accentstencil is offline Donating Member accentstencil Maloo accentstencil Maloo
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    I'm not entirely certain but I don't think the BCM controls the indicators or any of the lights.
    MY RIDE
    gunsmoke is offline Gunsmoke gunsmoke Executive
    VZ Exec
    Jun 2009
    Perth metro
    Hey all new member here........as above VZ commo, lock the doors with the keys and the LH indicators stay on when the car is deadlocked. I think its a common prob with this model. Wispers are its the BCM as above , needs replacing and keys re coded. Any one had this prob and solved it. thanks.
    VZ - S
    Apr 2009
    G'day gunsmoke just received your p.m.
    As it turned out there was actually a short within the right rear indicator assembly that caused all of the grief, so as it turned out it wasn't the BCM after all!
    My boss took it to his local Holden Service for them to analyze. I don't think it set him back too much either.
    Unfortunately my experience probably won't help with the problems that you're having with your indicator.
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa Doctor Bob GTO Doctor Bob GTO
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    Quote Originally Posted by gunsmoke View Post
    this is a known failure of the BCM, it can be repaired which would work out cheaper than replacing it & remotes & havng it all linked by a dealer.
    Cheers Rob
    VZ Executive
    Jun 2009
    I am having exactly that problem and boy am I pissed. my car is supposed to be under a 175 k warranty and they have told me the bcm is not covered and it will cost me $550.
    I didnt even know what a bloody bcm was, why the hell wouldnt it be covered?
    VZ Exec
    Jun 2009
    Perth metro
    Thanks all for the info. Dr Bob can you put me in touch with a repairer you speak of. BUT I am in WA, anyone here?
    We re pissed off at the BCM problem too! This should be a claimable item from GHM, its clearly a Holden failure.
    Thanks again.
    PS where is the BCM on a 04 VZ.
    383VXSS is offline 383VXSS 383VXSS Executive
    VXSS
    Jun 2009
    Geraldton
    My BCM died last year i sent it to Specialised auto electrics all fixed $190 frieghtinc.
    I live in country WA and had it back in a week.I recomended them in another post too cause he was great to deal with.Phone number 0423399286 Parramatta NSW
    You can get one cheaper from wreckers but the local autosparky here told me it was a common fault and 2nd hand one could do same thing,told me 2 have it fixed to b sure.Hope it helps.
    VZ Exec
    Jun 2009
    Perth metro
    Quote Originally Posted by 383VXSS View Post
    Thanks for the reply. A contact that works for GMH can do it for $500 incl new keys, but i think its a but much, maybe still thinking of going to GMH direct $550-$600??
    I will call Specialised Auto Elects too, thanks again.
  15. #15
    VZ Exec
    Jun 2009
    Perth metro
    VZ 2005 Executive Wagon
    Sep 2009
    Northern suburbs of Adelaide
    Quote Originally Posted by Doctor Bob View Post
    Cheers Rob
    Quote Originally Posted by tezza31 View Post
    FYI, I have sourced the relay inside the BCM, that is usually responsible for the indicators sticking on when the vehicle is locked. Have already supplied some relays to various folk, and it has fixed the problem in their vehicles. PM me for details.
  17. #17
    vs commodore
    Oct 2009
    Tamworth NSW
    I read somewhere the other day,maybe it was on here somewhere,that you can take the BCM apart,unsolder the faulty blinker relay from the BCM board,and solder in a replacement relay.This has gotta be a better option than buying new a BCM and new key fobs.
    EDIT:I found the PDF with the instructions on how to do this, but its too big to upload,so I posted a few pics from it which shows which relay inside the BCM stuffs up.This guys problem was his blinkers were sticking on when the car was locked or something along those lines.
    Attached Thumbnails Attached Thumbnails Body Control Module issues?-pic-relay.jpg   Body Control Module issues?-pic-relay-2.jpg   Body Control Module issues?-pic-relay-3.jpg   Body Control Module issues?-pic-relay-4.jpg   Body Control Module issues?-pic-relay-5.jpg
  18. #18
    VX Series 2 V8 Berlina Wagon A4
    Jan 2004
    Wantirna, VIC
    If anyone is in Melbourne and having issues with BCM with the indicator light sticking on a VZ, Conact user 'pezouni' who is a gun at fixing these issues. Thankd for taking a look at my car and fixing the issue for me in less than an hour.
    -= WAGEN3 =- VZ Monaro Kitted Wagon
+ Reply to Thread
  1. body control module
    By ausrs in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-06-2009, 02:50 PM
  2. body control module issues ?
    By Sammy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-10-2008, 04:41 PM
  3. Body control module
    By bluecar in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2007, 12:38 AM
  4. Body Control Module????
    By IMCRZY in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-03-2007, 12:33 AM
  5. Body Control Module
    By harvs01 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-01-2007, 05:40 PM
