Results 1 to 2 of 2
Thread: starting problems
    vr senator 215i hydratrac
    Apr 2009
    Default starting problems
    my 94 vr senator hydratrak 215i 5.7 6 speed wont start when warm its like the battrey is flat, but when it has cooled down it starts what is the cause of this and how to fix it or someone who can in the auckland area. cheers
    '95 215i 6spd Senator
    Oct 2005
    Pokeno NZ
    Quote Originally Posted by hydratrac View Post
    Hi mate....old thread I know but was just cruising the site. I have the same model and it did the same. One reason was its been decked so higher compression but the main reason was it was too far advanced. These things are pretty sensitive to any more than 10 degs. Also you need a good battery or it will always do it, something atleast 550CA. One thing I did do tho was installed a knock sensor negator. It cost me 20 bucks and was installed on the spot and did it make a difference....different car altogether, even idles better. If your local (which it looks like you are ) phat01 on JC has them and will do it for you . Good luck
  1. vl starting problems
    By kimbo1970 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 31-01-2009, 02:17 AM
  2. ignition problems or starting problems
    By Vs-AclaimII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2006, 04:55 PM
  3. Starting problems
    By Emu in forum General
    Last Post: 23-10-2006, 10:11 AM
  4. Starting problems with VS!Can u help?
    By vsbakkie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-08-2005, 08:35 PM
  5. Problems starting to appear
    By StealthX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-08-2005, 09:24 PM
