the alloytech is still fairly new to this kind of thing, you might be better of going witht he ecotec, alot more is known and availible for these.
hi there, have just started building a ve speedway car with a 195kw alloy tech, i was wondering if anyone has any info engine wat is done to a alloy tech to get them goin, cam grinds, has anyone taken the variable timming away, just any ifo would be helpful as not many people no about alloy tech engiens and wat gets horsepower out of them
cheers joel
have a look over in the states. they've been out for a while and tehy're making reasonable power from them.
brad should be able to sort something out tho
Chev badges are an instant fail
What class specifications do you have to follow, is there any in the class that you are in.
As this will depend on how far the modifications can go.
Give me a little more information on the car you are running, eg direct drive, or does it have a clutch etc etc...what rpm range will you be working in, gear ratio's, approx weight, ecu modifications allowed...what fuel, are you running pump fuel or methanol.
Regards Brad
Enhanced Automotive
www.enhancedautomotive.com.au
Blown LS1 8.2@173MPH
VL V8 NA 8.9@154MPH
HB Torana 333ci 9.4@146MPH
VY SS Ute Cammed & Nos M6 10.0@146MPH
VYSV8 Cammed & NOS M6 10.4@133MPH
VY SS Twin Turbo M6 525rwkw
LS1,LS2,LS3, L76 & L98 PERFORMANCE TUNING
VN/VP/VR/VS/VT/VX/VY/VZ/VE PERFORMANCE TUNING
CAM & HEAD PACKAGES, ENGINE PACKAGES
SPECIALISING IN ALL TYPES OF FORCED INDUCTION
ENHANCED AUTOMOTIVE
(08)8250 2233
