Results 1 to 17 of 17
Thread: line lockky kit!.. please read
    vs III commodore ute
    Sep 2008
    Talking line lockky kit!.. please read
    hey guys.
    im just after a kit/switch that shuts off the back breaks when you flick the switch. if any 1 knows where i can pick one up for a vs commodore or a place that installs them give me a comment or even any helpfull info. my mates car had one already installed when he got it and it saves the back breaks good. eg when skiding
    cheerz
    My CaR dOsNt ChErP gEaRs, It JuSt KiCkS sIdEwAyS!
    enhancedss's Avatar
    enhancedss is offline Enhanced Automotive enhancedss Executive
    VE R8 LS3, VYSS Ute 10.0@146MPH & VYSSTT 525rwkw
    Jun 2005
    SA
    Quote Originally Posted by 17UCK! View Post
    hey guys.
    cheerz
    Ive got a B&M one in my drag ute, works great.
    Where abouts are you located?
    www.enhancedautomotive.com.au
    Blown LS1 8.2@173MPH
    VL V8 NA 8.9@154MPH
    HB Torana 333ci 9.4@146MPH
    VY SS Ute Cammed & Nos M6 10.0@146MPH
    VYSV8 Cammed & NOS M6 10.4@133MPH
    VY SS Twin Turbo M6 525rwkw
    LS1,LS2,LS3, L76 & L98 PERFORMANCE TUNING
    VN/VP/VR/VS/VT/VX/VY/VZ/VE PERFORMANCE TUNING
    CAM & HEAD PACKAGES, ENGINE PACKAGES
    SPECIALISING IN ALL TYPES OF FORCED INDUCTION
    ENHANCED AUTOMOTIVE
    (08)8250 2233
    ve ss sportswagon!!!
    Dec 2008
    tasmania
    hey im interested in one of these 2. do u have any prices on these im located in tasmania, could u pm me a price please?
    Sep 2008
    brisbane
    Quote Originally Posted by enhancedss View Post
    Junny's Avatar
    Junny is offline purrrrrr Junny Executive
    VUII Maloo + shitty painted vp
    Hangman Champion!
    Jan 2009
    i'll buy the one from ur ute =] lol
    Hit the star under this post if it was any help to you =D
    holdenhero is offline Car idiot holdenhero Executive
    1998 VT
    Jan 2009
    Maroubra
    I've been researching these recently, the best one out seems to be the one sold by B&M. The rest seem to be copies and use inferior parts however you must note that B&M recommend that you only keep the kit activated for a max of 1 minute (however many people verify it works perfect after). The copy companies don't even give a timelimit on their product - I know it seems like if they don't give a time limit its better however looking at the types of solonoids they use it seems as if it wouldn't even last half a minute.
    Best I've seen a B&M kit going for on ebay was like $110 then you would need to get it fitted, but when dealing with your brakes its worth spending that bit extra isn't it?
    Another thing you might want to consider (if your electrically minded and willing to take the risk) would be to tap into your ABS module, as the ABS has the power to control brakes individually therefor you would be able to rig yourself up a switch which made the brakes stop working entirely by using your existing ABS module! Meaning you would only have to run an extra few wires for a switch and not actually tap into your brake lines etc...
    PS. The laws for differ from state to state as to wether 'line lock' kits are legal - Remember that its tampering with the cars brake lines!
    Not_An_Abba_Fan's Avatar
    Not_An_Abba_Fan is offline Exhaust Guru Not_An_Abba_Fan W427 Not_An_Abba_Fan W427 Not_An_Abba_Fan W427 Not_An_Abba_Fan W427
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Using the ABS would require some reprogramming. Disabling the ABS would only make the brakes come on regardless of motion. The ABS works by sensing wheel movement, if you wanted to keep the front brakes applied while having the rears moving it would require the module thinking that the rears weren't moving at all.
    Oh, and a lot of these kits won't work if the vehicle has ABS.
    Moroso Front Brake Line Lock Assembly, Racing, NEW:eBay Motors (item 260430691983 end time Jun-28-09 16:20:00 PDT)
    About $84 AUD, shipped.
    http://www.facebook.com/?ref=home#!/...21292461287296
    1998 VT
    Jan 2009
    Maroubra
    Can't you just wire a switch/button in that bypasses the module and makes the front brakes engage?
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    But the module would still receive the signal from the rear wheels. The brakes are applied by the pedal, not electrically, the module monitors wheel movement. When the module detects wheel lock up it cycles a solenoid that stops fluid from reaching that wheel. The braking system is still mechanical. You may be able to stop the ABS from working making the wheels lock up, but you wouldn't be able to prevent the brakes from working via the ABS.
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You! STEALTHY™ W427 STEALTHY™ W427 STEALTHY™ W427
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    Confirming that the B&M kit works perfectly fine with ABS
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    1998 VT
    Jan 2009
    Maroubra
    Interesting... was just a theory on the ABS anyway. I wouldn't be game to tamper with it on my own car haha.
    STEALTHY™'s Avatar
    Jan 2005
    Was referring to NAAFs post where he linked a line locker kit, and said alot don't work with ABS. I have been using the B&M one for years, and never a fault with the kit, or the ABS
    cheers sexy
    immortality's Avatar
    immortality is offline crappy ol' VN driver immortality W427 immortality W427 immortality W427
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    line lockers work with ABS (mechanically/hydraulic etc), it's just that some later model cars will have the ABS fault light show (becaue as NAAF mentioned, it senses the rear wheels spinning continuesly when the fronts aren't which is a condition the ABS unit is suppose to prevent). however it resets apparently when you switch the ignition off.
    Body by Holden, Soul by Brock
    the Legend will live forever
    VS Maloo
    Sep 2009
  15. #15
    vy berlina 5.7
    Mar 2010
    QLD
    STEALTHY™'s Avatar
    Jan 2005
    Quote Originally Posted by aussietim View Post
    whats the matter with a pair of vice grips
    Deterioration of the brake lines.......
    cheers sexy
  17. #17
    SS Fifty
    Apr 2007
    Vise Grips do damage the lines.
    I used to get the abs light come up in my VU after doing a skid, simple turn off and restart got rid ofit. guess it did a test or something.
    THe B&M linelocker kit is a good bit of kit, its the one I would go for..
  1. read read read!!!!attempted theft!!
    By CAM05L in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-03-2010, 05:01 PM
  2. vaccum line help
    By SICKTG in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-09-2008, 09:04 AM
  3. End of the Line for the WRX?
    By 1991_Vn2nV in forum The Pub
    Last Post: 22-04-2007, 03:38 PM
  4. Red Line
    By Caldys_vk in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-01-2007, 11:10 PM
  5. Exact VE model line up, Colours, Trim options, And HSV Line up. THE GTS IS BACK!!!
    By blackahcdx in forum VE Holden Commodore (2006 - ?)
    Last Post: 11-07-2006, 09:18 PM
