www.enhancedautomotive.com.au
Blown LS1 8.2@173MPH
VL V8 NA 8.9@154MPH
HB Torana 333ci 9.4@146MPH
VY SS Ute Cammed & Nos M6 10.0@146MPH
VYSV8 Cammed & NOS M6 10.4@133MPH
VY SS Twin Turbo M6 525rwkw
LS1,LS2,LS3, L76 & L98 PERFORMANCE TUNING
VN/VP/VR/VS/VT/VX/VY/VZ/VE PERFORMANCE TUNING
CAM & HEAD PACKAGES, ENGINE PACKAGES
SPECIALISING IN ALL TYPES OF FORCED INDUCTION
ENHANCED AUTOMOTIVE
(08)8250 2233
Why don't you also include the 25% under driven balancer? Seeing as the balancer comes off to install the cam anyway. It goes hand in hand with a cam install.
I dont include the balancer in the camshaft package as many customers do already have one fitted, so the balancer is an option.
However the only cost is for the balancer kit, no additional charge is added for labour as i do remove the balancer, to remove the camshaft from the vehicle.
Hopefully that answers your statement.
VL V8 NA 8.9@154MPH
ENHANCED AUTOMOTIVE
(08)8250 2233
you use it your own will m8 lol just dont get caught with it hooked up hehe
How does it work exactly.. like fast and the furious?...lol.... push the button and your car takes off? Is it dangerous at all?
most cars have it set-up to come on at W.O.T (wide open throttle) but they can also have an adjustable style aftermarket cpu to deliver it in stages at certain set rpm's
i proudly use and recommend
Enhanced Automotive - 1/11 Bremen Drive
Salisbury South - 8250 2233
Pushing The Limits In The Performance Industry
Nitrous will give a sudden increase in torque which will tax the cars tyres. IMO street tyres will turn into a cloud of smoke with a 150 shot. Even a 100 shot I tested at the track with street tyres caused an instant loss of traction.![]()
The progressive controller that I now use pulses the solenoids to limit the torque increase for a set period(either time or rpm based) & helps a lot in getting the power to the ground. I have found this necessary even with slicks on the 150 shot.
Hi Brad...
What rwkw could i expect from a cam package? I have a 2.5" system, mangaflow high flow cats, pacemaker tri-y's and an OTR.
Thanks.
Adamc11,
In answer to your question one of our customers VY's M6 makes approx 293 rwkw with our 'standard' street cam which is around the mark for this particular cam.
Here is a link which shows the dyno sheet on page 2.....
10.43@133 new PB for BradSV8 - Australian LS1 and Holden Forums
All our cams are Brad's custom grinds, so depending on what you want from the car, ie more top end power or maybe mid range, lumpy or maybe a bit more on the quiet side etc will depend on what Brad recommends or you!
Cathryn
Enhanced Automotive
1/11 Bremen Drive
Salisbury South SA
(08) 8250 2233
PUSHING THE LIMITS IN THE PERFORMANCE INDUSTRY
Thanks for your help Cathryn. Cam will have to wait a few months, can't wait to do it though![]()
Hey, just curious you know roughly the power achievable in a 304 (vs clubby) with just the cam + tune for your $3500?
VL V8 NA 8.9@154MPH
ENHANCED AUTOMOTIVE
(08)8250 2233
Hi I have a VT 5lt auto with 70mm throttle body,CAI,full exhaust system,195kw chip I want more low down power and lumpy V8 gurgle by installing a cam package what gains are expected?.Cheers any help would be great
As there are so many variables on power and torque output on the 5.0 ltr, best thing to do is give me a call on (08)8250 2233 and we will workout the right camshaft to suit your needs, and power output can be advised.
VL V8 NA 8.9@154MPH
ENHANCED AUTOMOTIVE
(08)8250 2233
