Page 1 of 4 1 2 3 4 LastLast
Results 1 to 25 of 82
Thread: Haltech Aftermarket ECU's
    enhancedss's Avatar
    enhancedss is offline Enhanced Automotive enhancedss Executive
    VE R8 LS3, VYSS Ute 10.0@146MPH & VYSSTT 525rwkw
    Jun 2005
    SA
    Default Haltech Aftermarket ECU's
    With a ECU available on the market to suit your application and vehicle type, here are the most common ECU's fitted to VL-VZ commodores.
    VN/VP Auto Manual
    VR/VS Manual Only
    VT/VZ Manual Only
    E6GMX suggested for application fitted and tuned from $1700 Driveaway.
    VR/VS Auto/Manual
    VT/VZ If wanting to remove MAF and have full control on fuel & ignition parameters.
    E6X suggested for application fitted and tuned from $2400 driveaway
    For outright drag/race car applications E11v2 suggested depending on application.
    www.enhancedautomotive.com.au
    Blown LS1 8.2@173MPH
    VL V8 NA 8.9@154MPH
    HB Torana 333ci 9.4@146MPH
    VY SS Ute Cammed & Nos M6 10.0@146MPH
    VYSV8 Cammed & NOS M6 10.4@133MPH
    VY SS Twin Turbo M6 525rwkw
    LS1,LS2,LS3, L76 & L98 PERFORMANCE TUNING
    VN/VP/VR/VS/VT/VX/VY/VZ/VE PERFORMANCE TUNING
    CAM & HEAD PACKAGES, ENGINE PACKAGES
    SPECIALISING IN ALL TYPES OF FORCED INDUCTION
    ENHANCED AUTOMOTIVE
    (08)8250 2233
    vn/vp Speedway Street Sedan
    Sep 2005
    Cool $ounds too dear!
    "E6GMX suggested for application fitted and tuned from $1700 Driveaway"
    Gee that sounds a bit dear!
    I purchased an E6GMX for $1050
    Had it mapped, dynoed and tuned for approx $300.( They had it on the dyno a long time as it was not running well w ith the stock computer when we first put it on and they sorted out an issue with a sensor etc.
    Unless the prices have gone up outrageously in the last 12 months!
    enhancedss's Avatar
    Jun 2005
    SA
    Quote Originally Posted by Rhino Racing View Post
    This is straight from Haltech themselves
    The E6GMX Kit includes:
    ECU Programmable Computer, Instruction Manual on CD, Programming Disk, Patch Loom,
    Programming Cable, Haltech Stickers.
    RRP: $1190 AUD
    + fitting of 10minutes + dyno tuning.
    Im gathering the car they fitted it to was for the vehicle mentioned in your title a speedway car... so what fuel consumption are u getting from the vehicle, or did they just tune the vehicle for peak power?
    As the factory tune they supply with the ECU, yes it will start and run the vehicle, which we all know the fuel consumption and driveability of the vehicle is the key factor, so have u payed for a custom tune or a few peak power runs....thats the question you have to ask yourself.
    VL V8 NA 8.9@154MPH
    ENHANCED AUTOMOTIVE
    (08)8250 2233
    VU S Ute
    Nov 2006
    Penfield SA
    How much for the E11v2 setup? on a VU V6 Auto (going full manual shift though)
    Life without challenge........ May as well be dead !
    Watch out for the Two Tone ute terrorising a city near you
    Raptor Superchargers... More than just a good Blow Job
    vz
    Mar 2004
    SA
    Brad..
    Just wondering what the difference is with the Haltech compared to the stock Holden ECU ?? can the Haltech be tuned better ??
    enhancedss's Avatar
    Jun 2005
    SA
    Quote Originally Posted by TigaMite View Post
    Brad..
    Depending on your application, for example fuel and ignition tables have alot more adjustments than the early ECU's, also boost friendly means excellent for power and drivability whislt on and off boost, fuel economy with other key factors eg 2 stage tunes, also built in boost contollers and turbo timers etc etc....
    Its just the same as a VT-VY LS1 PCM, compaired to the VE E38 PCM, with twice as many tuning points achieveable, take for example the fueling tables, the VT-VY adjustments are every 400rpm and every 5kpa, where the E38 PCM, give u the ability to adjust down to every 200rpm and or 2 kpa.
    the E38 tuning programme just gives even better drivability, engine protection etc.....but would do the expensive upgrade on your vehicle...no u wouldnt, its the same with the Haltech, for modified vehicles then yes, it a very worthy upgrade, but this depends on modifications on each and every individual.
    VL V8 NA 8.9@154MPH
    ENHANCED AUTOMOTIVE
    (08)8250 2233
    vz
    Mar 2004
    SA
    Thanks for answer Brad... you read my mind lol . Not bad for a young fella
    VC,VK, VN
    Feb 2007
    Quote Originally Posted by enhancedss View Post
    VN/VP Auto Manual
    VR/VS Manual Only
    VT/VZ Manual Only
    VR/VS Auto/Manual
    Im after a Haltech for my VN V6. I like the Haltech but of course you need a tuner that works with them.
    Your the guy in Salisbury right
    enhancedss's Avatar
    Jun 2005
    SA
    Quote Originally Posted by stroke it View Post
    List what modifications you have. As u might be better of with a custom memcal to suit your application.
    Located at
    1/11 Bremen Drive,
    Salisbury South SA
    VL V8 NA 8.9@154MPH
    ENHANCED AUTOMOTIVE
    (08)8250 2233
    VC,VK, VN
    Feb 2007
    Located at
    1/11 Bremen Drive,
    Salisbury South SA
    I have an L67 to put in but i dont have the computer or its transmission just the complete motor/blower. I was thinking purchase a Haltech and retain the non electric vn trans.
    What do you think?
    Bilbs's Avatar
    Bilbs is offline Donating Member Bilbs Berlina
    VR 5.0 M5 Ute
    Apr 2007
    Churchill
    I been thinking bout halltech for quite a while now, so few q's
    The 2 stage tune, is that meaning you can have a button that you can push and she sets up for peak power, and just econ when off, or is it nothing like that
    2, It is a replacement, and not just a piggyback im hoping
    3, Is it worth it for my car - VR Ute, V8 Man, extractors, single 2 1/2 straight through mufflers, cold air intake, k&n filter, but in the future, im most likely gonna stroke to 333 or 355, just not sure yet
    And last, if fitted to my current setup, what kinda power/consumption would be achievable?
    enhancedss's Avatar
    Jun 2005
    SA
    Quote Originally Posted by Bilbs View Post
    Due to the model of the car u have there are 2 ways we can tune the vehicle, either remap the factory memcal, or we can install a direct plug in E6GMX, both of these computers will have the ability to net u great gains.
    the 2 stage tune, i use only for turbo equiped cars. This is setup with a boost controller, making dual setting boost pressure. Im firmly a believer that the car should be tuned only on 1 tune, not a switched setup.
    VL V8 NA 8.9@154MPH
    ENHANCED AUTOMOTIVE
    (08)8250 2233
    Bilbs's Avatar
    VR 5.0 M5 Ute
    Apr 2007
    Churchill
    enhancedss's Avatar
    Jun 2005
    SA
    so, just asking, are those halltech ecu's difficult to tune, as i do have access to a dyno at work
    The tuning software is very easy to use, knowing whats going on when tuning a car is an art.
    VL V8 NA 8.9@154MPH
    ENHANCED AUTOMOTIVE
    (08)8250 2233
  15. #15
    Dan355's Avatar
    Dan355 is offline Go THE SS's Dan355 Calais
    Street Legal 355ci VN SS - Daily: VP SS
    May 2006
    Do you know the difference between the E6GM and the E6GMX? Is the E6GM the older version?
  16. #16
    Bilbs's Avatar
    VR 5.0 M5 Ute
    Apr 2007
    Churchill
    So have you guys heard of using say tuner pro, and memcal emulation, say a prominator, which can be tuned on the fly, using the delco management, as i have been told by so many people, that nothing beats a delco management system
  17. #17
    enhancedss's Avatar
    Jun 2005
    SA
    Quote Originally Posted by Dan355 View Post
    E6GMX is windows based
    E6GM is MS Dos based
    VL V8 NA 8.9@154MPH
    ENHANCED AUTOMOTIVE
    (08)8250 2233
  18. #18
    enhancedss's Avatar
    Jun 2005
    SA
    there are plenty aftermarket ECU's that are more tuneable than the delco system.
    if the delco system was the ants pants for example in the vn range or the vr range, why would the manufactors upgrade it and improve on.
    As for your question i use, Tunercat Pro, with realtime emulation, erase and reburn memcals for VN-VR & VS V8
    Kalmaker for other models eg VT-VY
    VCM Suite for VZ V6 tuning
    EFI Live for LS1/2 tuning
    VL V8 NA 8.9@154MPH
    ENHANCED AUTOMOTIVE
    (08)8250 2233
  19. #19
    Dan355's Avatar
    May 2006
    Do they both have the same tunability?
  20. #20
    enhancedss's Avatar
    Jun 2005
    SA
    Tuneability very very similar, however windows based software is far better, and quicker for tuning.
    Plus my old ms dos laptop does like being opened anymore...
    VL V8 NA 8.9@154MPH
    ENHANCED AUTOMOTIVE
    (08)8250 2233
  21. #21
    UNKNOWN's Avatar
    UNKNOWN is offline DEFECTED UNKNOWN Executive
    95 VR SII BT1 5 Speed
    Jan 2008
    NW Adelaide
    Hey, I have an E6GMX siting around. I have a VR V6 manual but im running the auto loom. I want to use this ecu though. Is there any way I can get around having to FIND and change the loom to a manual one to use this ecu?
  22. #22
    Dan355's Avatar
    May 2006
    Ah k. Can you change it so the E6GM runs the windows software? Would there be much advantage using the E6GM over the standard ECU and Memcal?
  23. #23
    enhancedss's Avatar
    Jun 2005
    SA
    No this can be done it MS Dos based only. This is the reason why they released the E6GMX as it far more user friendly.
    As for an advantage, yes if tuned correctly. The biggest advantage with aftermarket ECU's, is ignition charge time which cant be touched when tuning the factory ECU.
    VL V8 NA 8.9@154MPH
    ENHANCED AUTOMOTIVE
    (08)8250 2233
  24. #24
    enhancedss's Avatar
    Jun 2005
    SA
    Quote Originally Posted by UNKNOWN View Post
    As ive done before many times, as a manual wiring harness isnt the easiest to come across, i actually rewire the wiring harness at the ECU, and install new connectors, to allow the car to be fitted with a E6GMX.
    Last week i just finished wiring and tuning a E6GMX into a Torana fitted with a Corvette TPI Engine, so as u see we install E6GMX's on many different combo's.
    VL V8 NA 8.9@154MPH
    ENHANCED AUTOMOTIVE
    (08)8250 2233
  25. #25
    UNKNOWN's Avatar
    Jan 2008
    NW Adelaide
    How would I go about doing this? Im handy-ish whith a soldering iron and not afraid to give it a shot!
  1. Ecu's
    By vsII manual in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-07-2009, 05:24 AM
  2. Haltech E6GMX
    By Hillerus in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-10-2006, 12:02 PM
  3. PWR ECU's
    By Stretchomatic in forum LSx Development and Modification
    Last Post: 19-01-2006, 06:56 PM
  4. FS- Haltech Interceptor
    By enhancedss in forum Parts And Other Items For Sale
    Last Post: 09-10-2005, 02:11 AM
  5. Haltech E6gm-8
    By OSL-060 in forum General
    Last Post: 07-01-2004, 05:13 PM
