Results 1 to 20 of 20
Thread: VY TT 505rwkw@12psi
    enhancedss's Avatar
    enhancedss is offline Enhanced Automotive enhancedss Executive
    VE R8 LS3, VYSS Ute 10.0@146MPH & VYSSTT 525rwkw
    Jun 2005
    SA
    Default VY TT 505rwkw@12psi
    Just an update on the Twin Turbo VY, after many dyno power runs, camshaft changes all as R&D on the vehicle, testing maximum boost, Intake Air Temperatures under all different boost conditions, the turbo's originally fitted to the vehicle were just not big enough for the latest camshaft grind, and only producing 14psi.
    So after a few changes in the location of the new garrett turbo's, a couple intercooler pipe modifications, installation of twin 38mm external wastegates, with screamer pipes.
    The car fired into life on Saturday morning, just a few hours before Street Commodores dyno day, held at Graham West Workshops (Park Holme)
    From what was said on the day, the dyno readings were down approx 30kw's and 50kw's from a VX SS which id recently seen on the previous dyno day held here in SA.
    The car was washed, safe tune installed, and then driven down for the dyno day, boost was controlled by a Turbosmart Boost T (slightly modified), as time wasnt there for setting up the greddy boost controller.
    As the car hadnt been on the dyno with this new combination the tune was left extreamly safe, meaning there is plenty more in reserve.
    I was extteamly happy with the overall results from the vehicle, on such a safe tune and little boost, boost will be wound up to 22 PSI.
    In the dyno graph above, the maximum boost pressure recorded 12.3PSI, in such a low comp engine, even the operator and owner of the dyno, estimates 650-700rwkw from this little 346ci alloy block LS1.
    Just an update, i finally found time yesterday afternoon to spend a few hours on the car.
    After exceding the torque limits of the dyno in 4th gear with 3.46's, 5th gear was used.
    after running the vehicle on the dyno and only producing 460rwkw, with the same tune and same boost levels 15kw's down from previous dyno run on a mainline dyno.
    Here are the results. after further tuning.
    www.enhancedautomotive.com.au
    Blown LS1 8.2@173MPH
    VL V8 NA 8.9@154MPH
    HB Torana 333ci 9.4@146MPH
    VY SS Ute Cammed & Nos M6 10.0@146MPH
    VYSV8 Cammed & NOS M6 10.4@133MPH
    VY SS Twin Turbo M6 525rwkw
    LS1,LS2,LS3, L76 & L98 PERFORMANCE TUNING
    VN/VP/VR/VS/VT/VX/VY/VZ/VE PERFORMANCE TUNING
    CAM & HEAD PACKAGES, ENGINE PACKAGES
    SPECIALISING IN ALL TYPES OF FORCED INDUCTION
    ENHANCED AUTOMOTIVE
    (08)8250 2233
    VY S PAC 5 speed
    Apr 2007
    WA
    Boonz's Avatar
    Boonz is offline the holden mechanic Boonz Maloo Boonz Maloo
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    very impressive figures, how come you only took it to a little above 5000 revs???
    1991_Vn2nV's Avatar
    1991_Vn2nV is offline Donating Member 1991_Vn2nV GTS 1991_Vn2nV GTS
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    Hey man, awesome results. I f***in love this car! Cant wait to see what happens when the boost is wound up
    enhancedss's Avatar
    Jun 2005
    SA
    Quote Originally Posted by HoldenMan7 View Post
    Hey Mate, thats very impressive, you ran it down the 1/4 mile ??
    will be very shortly, just have to downsize brakes, fit rims and slicks and change suspension to suit.
    I will keep u posted on the times it runs, when i do decide to take it down the 1/4 ive only got 1 chance at a 10sec pass, as im not fitting a gage to the family car, my drag ute will be a different story thou.
    VL V8 NA 8.9@154MPH
    ENHANCED AUTOMOTIVE
    (08)8250 2233
    enhancedss's Avatar
    Jun 2005
    SA
    Quote Originally Posted by Peanuts Inc. View Post
    much appreaciated, the engine seems to be losing power up top, but also being on boost for a long period of time, IAT's rise dramatically where the vehicle is going to lose power anyway. When i get more time to spend on the vehicle i will carryout further testing and diagnose the actual cause.
    VL V8 NA 8.9@154MPH
    ENHANCED AUTOMOTIVE
    (08)8250 2233
    enhancedss's Avatar
    Jun 2005
    SA
    Quote Originally Posted by 1991_Vn2nV View Post
    Dylan, start saving your pennies, as the vehicle will be up for sale soon if everything goes to plan, you should come for a ride in the vehicle with the latest setup, it makes the blower look shameful, with the mid range power absolutly awesome are the only words i can describe it, with 4 in the car top of 3rd gear, 80ltrs of fuel on board, squeeze the throttle and instant smoke.
    VL V8 NA 8.9@154MPH
    ENHANCED AUTOMOTIVE
    (08)8250 2233
    1991_Vn2nV's Avatar
    Mar 2006
    Ahh man, when it had the blower on that blew my mind, I cant imagine what its like now
    Hopefully i'll get to see it soon mate
    AttaBoy is offline WTF?!?! AttaBoy Statesman
    VS Acclaim V6
    May 2005
    enhancedss's Avatar
    Jun 2005
    SA
    Quote Originally Posted by AttaBoy View Post
    How much you willing to sell it for?? Estimate price??
    Give me a call, and i will discuss a price. I didnt want to set a price it would be more of a offer, or i will strip the components of the car, and sell the car as a normal VY SS.
    VL V8 NA 8.9@154MPH
    ENHANCED AUTOMOTIVE
    (08)8250 2233
    VP Executive R-spec
    Jan 2005
    Quote Originally Posted by enhancedss View Post
    You'll have to run a few strong half tracks to get the launch sorted and jump on the brakes :P then once your confidant it you have it launching as good as it's going to run drive it home for the win. Is that the plan? I've seen lots of gigwatt supras struggle to beat cars with less than half their power though, because they come on boost so hard it's almost impossible to drive them fast without it all going up in smoke
    enhancedss's Avatar
    Jun 2005
    SA
    Quote Originally Posted by greenfoam View Post
    Yes that was the plan, had a few hicups through out the day, flatspotted front runners and slicks, and enilated a clutch, still managed to do a 130MPH pass with these faults.
    VL V8 NA 8.9@154MPH
    ENHANCED AUTOMOTIVE
    (08)8250 2233
    GTP 85's Avatar
    GTP 85 is online now 291 hp @ the wheels GTP 85 Statesman
    VS V6, VN V8, VR SS
    Aug 2006
    Adelaide, near the bay
    What a monster this car is! It always has me guessing every time i see it.. what is lurking underneath the bonnet this time!
    great work
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, comp and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    enhancedss's Avatar
    Jun 2005
    SA
    Quote Originally Posted by REV-231 View Post
    great work
    Thats it mate this cars voyage has come to an end, after this weekends extreme horsepower show, the car gets stripped and installed as a cammed LS1, manual, brakes, suspension, wheels etc will stay as is, as the new plan for the car is entirly a tow car for the drag car.
    The new project a purpose built drag car. I might do a build thread on this one.
    So i have for sale,
    dual pump fuel system,
    built LS1 forged pistons, lunati everything, rollers etc(way to much to list)
    twin turbo kit, with extrusion intercooler, garrett turbo's, extrenal waste gates, screamer pipes etc etc.
    Twin 3" Exhaust system etc....
    Any enquiries feel free to give me a buzz,
    VL V8 NA 8.9@154MPH
    ENHANCED AUTOMOTIVE
    (08)8250 2233
  15. #15
    vz
    Mar 2004
    SA
    Would it be sold with a working clutch ????
  16. #16
    enhancedss's Avatar
    Jun 2005
    SA
    Quote Originally Posted by TigaMite View Post
    Tezza, are u interested in the clutch for your own car......
    The for sale add for the clutch would be something along these lines.
    For Sale,
    clutch, done several drag strip passes, clutch felt brilliant when new, would suit vehicles with far less power, looking for new home behind a MAF equiped LS1 vehicle(eg the old widdle VT)...........
    Nah the clutch will be replaced, and will serve its purpose in the tow car.
    ps. had one of your mates call me the other day to book in for a tune, he reckons your a crazy old bloke behind the wheel when your wearing your bowling hat.....
    VL V8 NA 8.9@154MPH
    ENHANCED AUTOMOTIVE
    (08)8250 2233
  17. #17
    PaRaDoX's Avatar
    PaRaDoX is offline boosted! PaRaDoX ClubSport PaRaDoX ClubSport
    VT S Super6, STI Liberty GT, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    i remember seein this thing at the drags at heathcote, dammm does it make sexy noises lol
  18. #18
    VY SS UTE
    May 2008
    bunbury W.A
    hey there, how much u asking for the tt kit, is everything there that i need to slapp her on a stock vy ss??
    pm please
    thanx in advance
  19. #19
    VT feature car, WRX STI WAGON
    Aug 2006
  20. #20
    VN SV3800
    Sep 2008
    wow that car is mental. seen your ute out at whyalla earlier this year... tuff as
