Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 26 to 50 of 65
Thread: Specials
  1. #26
    adamc11 is offline Donating Member adamc11 Executive
    VY SS
    Feb 2008
    E. & W. Suburbs Melbourne
    Quote Originally Posted by DVSV8 View Post
    can i get the tune done now and a cat back later? or would it be better to do it the other way?
    You can get the tune down now and spec it to the mods you will have later... you might see fuel consumption increase and power too. You won't notice too much power from a cat back alone. I'd get the tune done while it is on special.
  2. #27
    enhancedss's Avatar
    enhancedss is offline Enhanced Automotive enhancedss Executive
    VE R8 LS3, VYSS Ute 10.0@146MPH & VYSSTT 525rwkw
    Jun 2005
    SA
    Quote Originally Posted by adamc11 View Post
    Hi Brad.. yes the tune was well worth the money... car goes much better... i think i'll be looking at a cam package next, i'm rather liking the power the LS1's have . Will my pacemaker tri-y's be ok for a big cam?
    Anyway, following up cpbait's post... do you lock the tune so it cannot be modified and all settings viewed? If you go to get a proper LS1 edit down the track, how does that work? Does the person tuning it have to reset it to stock then tune it to their specs? Is that why you charge $170 if it is locked?
    I was speaking to my uncle about the tune... he has an LS1 auto wagon and may consider a tune. He wanted to know how it worked (i'm curious too)... Do you have a whole range of tunes that you have done to cars with various specs and saved them for future use? So say for my situation, you have tuned a car with an OTR and 2.5" twin system with pacemaker tri-y's, saved that tune then used it for my mail order tune?
    Also, did you re-calibrate my average fuel readings or have they been untouched? Will post back here with fuel consumption figures in a few days for those interested.
    Thanks.
    To be completly honest throw the try-why's in the bin, a good tune will increase bottom end power over what try-why's claim to give. 1 3/4's 4 into 1's are normally the best if planning on future modifications.
    Many guys travel from interstate for a camshaft package as we are roughly only 7 hours away from Melbourne or 1 tank of fuel.
    Many companies will lock the tune, i for one do. As ive spent far to many hours just to give up valuable information at the drop of a hat. In actual fact even the PCM is locked from factory, its just that our software can unlock the generic password protected codes.
    If you decide to get the car retuned, simply send back the PCM and i will remove the tune, and reinstall a factory tune that will be only factory password protected.
    At the end of the day, if the tuner that you take your car to, wants the tune to be unlocked and just tweaked, then obviously he hasnt done his job correctly before even attempting to tune your vehicle. There is tuners and then there's tuners, so what are you really paying for.
    As for the tunes that get burnt in to a mailorder, these tunes are designed by myself, and tested and tested before i released a mailorder tune to the public, basically every car that i custom tune starts of as a mailoder and then gets tweaked to suit that individual combination. What 1 tune will work in one car wont produce power figures of the same in another car.
    As for fuel guage calibrations, no i didnt make any adjustments, its just the factory tune, is extreamly rich as a basis and then closed loope fuel control is used on top to get decent fuel economy from factory. This is probably the easiest way i can say it, the VT LS1, came out producing this much power, and economy was this much, the VZ came out of the factory with that much power and better economy but still has basically the same engine. Even the HSV range has the itentical driveline but produces more power and better economy.
    www.enhancedautomotive.com.au
    Blown LS1 8.2@173MPH
    VL V8 NA 8.9@154MPH
    HB Torana 333ci 9.4@146MPH
    VY SS Ute Cammed & Nos M6 10.0@146MPH
    VYSV8 Cammed & NOS M6 10.4@133MPH
    VY SS Twin Turbo M6 525rwkw
    LS1,LS2,LS3, L76 & L98 PERFORMANCE TUNING
    VN/VP/VR/VS/VT/VX/VY/VZ/VE PERFORMANCE TUNING
    CAM & HEAD PACKAGES, ENGINE PACKAGES
    SPECIALISING IN ALL TYPES OF FORCED INDUCTION
    ENHANCED AUTOMOTIVE
    (08)8250 2233
  3. #28
    enhancedss's Avatar
    Jun 2005
    SA
    The mailorder tune was designed for this exact reason, to give the guys doing modifcations over time, and wanting to achieve great power gains and economy without waiting till the end.
    I doesnt matter what order you get it done, most of my customers start of with a mailorder tune, then move onto an exhaust system, air intake, throttle body, underdrive balancer, and finally come to see me in the end with a touch up tune to achieve the best results i can from there particular combination.
    VL V8 NA 8.9@154MPH
    ENHANCED AUTOMOTIVE
    (08)8250 2233
  4. #29
    VY SS
    Feb 2008
    Quote Originally Posted by enhancedss View Post
    Should have spoken to you before i got the tri-y's then aye (1 5/8 i believe). Oh well, i still noticed a fair gain from them. If down the track i decide to change them, what ones should i go for... Pacemeaker tuned length?
    Also if possible could you show us some pictures of your alloy OTR. It's the next thing i'll be getting so am very interested.
    Thanks.
  5. #30
    CANYONERO's Avatar
    CANYONERO is offline Likes Cheese... CANYONERO Calais
    V8 6spd wif MOMO leavaa.
    Mar 2006
    Country SA
    well if this is the case, you will more than likely see me thursday morning!
  6. #31
    vy ss commodore 5.7ltr
    Jul 2006
    oh cool, so i can get a mail order tune and add my exhaust and otrcai after, and it will still drive and run fine b4 and after the mods with the tune?
    will i still get gwd economy and power out of the mail order tune b4 these mods and even better after the mods have been added?
    very interested still, how much would a touch up tune that u mentioned cost once these extra mods have been added if i want it dyno tuned? is it full price or less due to majority of the tune already done?
  7. #32
    VY SS
    Feb 2008
    Quote Originally Posted by cpbait View Post
    Yes will be fine before and after... this is what i'm doing as i don't yet have an OTR.
    Yes you should see economy improvements. As yet i havn't seen a whole lot as i've really been giving the car some sh*t, but next tank of fuel i'll drive as usual and should hopefully see some nice figures.
    You decided what extractors to go with?
  8. #33
    Jul 2006
    oh cool, yeh thats what i thought, just wanted to make sure, yeh let us know how ur next tank goes, i'm going to be giving brad a call soon, i have decided on magna flow 2.5" in/out hi-flow cats and x-force stainless cat back system, just not sure on hotdogs in the centre or mufflers with the rear muffler, depends on what the drone will be like with the mailorder tune on a vy auto, headers had decided on tri-y's pacemaker, but after reading some of brads recomendations in these posts, i think i'll get 4 into 1's stainless, but not sure what brand is gwd, maybe x-force or get pacemaker tuned length headers as mentioned b4. but will talk to brad.
    u decided yet?
  9. #34
    VY SS
    Feb 2008
    u decided yet?
    I went with the pacemaker tri-y's... Did some reading around and its about half and half, some say tri-y's and others tuned length 4 into 1's. I noticed a big difference from the extractors, especially mid range power, so i'm very happy with the result. If i go cam in the future (which i'm seriously considering), then i might scrap the tri-y's and throw on some 4 into 1's if it'll pump out more power, but keep the 2.5" system.
    The cat back exhaust i have is a press bent one, i'm going to change it to a mandrel bent 2.5"... i spoke with brad and he said xforce were good, recommended them over redback. As for stainless steel not really sure if it's worth the extra $$$...
  10. #35
    enhancedss's Avatar
    Jun 2005
    SA
    Here is a pic of the OTRCAI
    VL V8 NA 8.9@154MPH
    ENHANCED AUTOMOTIVE
    (08)8250 2233
  11. #36
    enhancedss's Avatar
    Jun 2005
    SA
    Thanks.
    The extractors i find that work the best all round, are Pacemaker 1 3/4 4 into 1's
    VL V8 NA 8.9@154MPH
    ENHANCED AUTOMOTIVE
    (08)8250 2233
  12. #37
    enhancedss's Avatar
    Jun 2005
    SA
    Touch up tune costs, are approx $300-$500 depending on time required.
    VL V8 NA 8.9@154MPH
    ENHANCED AUTOMOTIVE
    (08)8250 2233
  13. #38
    vz
    Mar 2004
    SA
  14. #39
    Jul 2006
    oh sweet as, thanks brad, yeh thats good, yeh i'm leaning in favour of the pacies, tri-y's, i'm in melbourne and work in the automotive industry and not far from the xforce and dandenong pacemaker places so i'll buy direct of them and fit them myself, just not sure if to get hotdogs in the middle or centre mufflers, that otrcai looks gwd, how much is that brad through u?
    adamc11 how much did u pay for your pacies if u don't mind me asking? iv had quotes of $1,000+ just for the tri-ys.
  15. #40
    VY SS
    Feb 2008
    cpbait, i posted a reply in your other thread.
  16. #41
    enhancedss's Avatar
    Jun 2005
    SA
    The extractors are the same price to purchase, so why buy the try-whys?
    just go straight to the 4 into 1's, but they are a bit harder to install.
    Cheers Brad
    VL V8 NA 8.9@154MPH
    ENHANCED AUTOMOTIVE
    (08)8250 2233
  17. #42
    VY SS
    Feb 2008
    So when i come to get the car properly tuned, it will be $300-$500? In that case i can justify driving to adelaide just for a proper tune, as a proper tune anywhere else will cost about $1000.
    Also with the cam package, does the $3000 include a tune? If not, how much would a touch-up tune cost if i cammed the car... $500?
  18. #43
    Jul 2006
    yeh i'm pritty sure the cam package includes the tune.
    adamc11, yeh i replyed to this thread then saw it in the other thread.
  19. #44
    enhancedss's Avatar
    Jun 2005
    SA
    The $300-$500 Charge is for touch up tunes, this is to cover dyno running time.
    The camshaft package does include a custom dyno tune.
    VL V8 NA 8.9@154MPH
    ENHANCED AUTOMOTIVE
    (08)8250 2233
  20. #45
    VY SS
    Feb 2008
    A touch up tune is the same as a proper tune correct?
  21. #46
    enhancedss's Avatar
    Jun 2005
    SA
    correct Adam, im sorry if i didnt clarrify this.
    Mailorder tune + touchup tune = custom dyno tune (proper tune)
    VL V8 NA 8.9@154MPH
    ENHANCED AUTOMOTIVE
    (08)8250 2233
  22. #47
    VY SS
    Feb 2008
    Ok great. Will be seeing you later in the year then when she goes in for a full tune, or even better a cam.
  23. #48
    CANYONERO's Avatar
    Mar 2006
    Country SA
    Thanks brad for the tune today. very happy. i'll def be back for more mods (when i can afford it! )
  24. #49
    enhancedss's Avatar
    Jun 2005
    SA
    Im glad you like it Will, just dont get caught speeding now.
    VL V8 NA 8.9@154MPH
    ENHANCED AUTOMOTIVE
    (08)8250 2233
  25. #50
    VY SS
    Feb 2008
    Brad what other OTR intakes do you have that are cheaper than the alloy one. Might spare the good looks and go plastic.
  1. BlueChip Tuning Specials
    By Darren in forum News/Updates
    Last Post: 02-04-2007, 03:08 PM
  2. Specials in Melbourne??
    By Thomas1 in forum Car Audio
    Last Post: 06-02-2007, 11:12 PM
