Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Sponsors > FIT - Forced Induction Technologies
FIT - Forced Induction Technologies V6 Supercharged Specialists - http://www.v6supercharged.com.au
LinkBack Thread Tools Display Modes
  #1
Old 29-09-2005, 05:12 PM
flip1906's Avatar
Ride: supercharged vs stato
Trade Rating: (0)
flip1906 Executive
Default recommended pulley upgrade
Looking at 10psi Pulley Upgrade for my Factory Supercharged V6 (VS Calais) is it worth getting the pulley upgrade ?
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
  #2
Old 25-01-2006, 04:36 AM
Tonsta V6 S/C's Avatar
Ride: VT CALAIS Supercharged V6
Trade Rating: (0)
Tonsta V6 S/C Executive
Increasing the boost is the easiest, quickest and best way to greatly improve power output, torque and acceleration, without sacrificing drivability and fuel economy. From 6psi (factory standard) Boost Pulley's are available in to Increase Boost to 10psi Safely and can be installed without having to remove the supercharger!
Without a doubt, this will give you a greater power and torque increase per dollar than any other modification!
This takes your engine from the standard 171kW to over 200kW straight out of the box if you have upgraded your exhaust system as well !!
More info can be found here:
http://www.v6supercharged.com.au/pulley.asp
Hope this helps.
Regards
Tonsta
__________________
Home of Australias Fastest and Most Powerful M90 Supercharged V6's
  #3
Old 11-04-2006, 02:55 AM
mattman's Avatar
Ride: '00 WH V6
Trade Rating: (0)
mattman Berlina
Howdy..
What exactly is the process to fit the 10psi pulley? I've had a bit of a poke through your site and basically all it says is the standard pulley is a b*tch to get off... like is this something I could do myself or a local mechanic? Or would I be better off going to see someone with more experience with the L67 (probably noone in Adelaide).
Also I assume that the 10psi pulley in no way reduces the life of the engine? Just that i'd be better off running 98RON rather than 95RON.
Cheers,
Matt
__________________
  #4
Old 12-04-2006, 10:01 PM
Ride: 2x VS
Trade Rating: (0)
sixshooter Statesman
Agh jeez Matty you're too much... you're already wanting more boost and haven't even sat in the drivers seat yet...
__________________
Disclaimer For The Reader ::
The information I provide is freely given to ONLY help you with thinking on problem solutions. IT IS NOT a "How To Do It Guide".
If you read ANY of my supplied information and use ANY of it you must accept and agree to do so AT YOUR OWN RISK
or do not use the information at all
I accept NO liability if you damage your or anyone elses property or cause any harm to yourself or others with the information provided.
I am NOT a Mechanic. You have been warned.
  #5
Old 12-04-2006, 11:26 PM
mattman's Avatar
Ride: '00 WH V6
Trade Rating: (0)
mattman Berlina
Heh... can't blame a guy for tryin :P
Everything is just going into the memory banks for now... see what it's like if/when i get it... then decide what needs doing..
__________________
  #6
Old 20-04-2006, 08:34 AM
Trade Rating: (0)
The factory pulley is very difficult to get of without the right tooling.
We have a special tool which we loan out with the 10psi Upgrade Kit which makes it a simple process taking around 30-40mins.
You can DIY with general home handyman tools or have your local mechanic perform it for you,
Hope this helps.
Regards
Tonsta
__________________
  #7
Old 20-04-2006, 08:41 AM
mattman's Avatar
Ride: '00 WH V6
Trade Rating: (0)
mattman Berlina
Cheers!
Looks like rockers might be the go though for a first upgrade.. little more pricey but just as much increase and no need for 98RON
Now.. the car... hehe.. I do need to buy that I suppose.
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Recommended Stereo Infest Car Audio 38 30-10-2006 03:08 PM
pulley upgrade or straght chip flip1906 V6 Development And Modification 8 07-11-2005 09:15 PM
Recommended Wreckers VNwagMan VN - VP Holden Commodore (1988 - 1993) 1 23-03-2005 01:29 PM
Recommended Carby mza VB - VK Holden Commodore (1978 - 1985) 9 07-04-2004 08:25 AM
Auto Test, Bewertung, Infos | Credit Cards | Air Jordans | Homeowner Loans | Mobile Phones | Car Reviews
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
