Yes, would actually be even better than the M90 as it wouldn't need to work as hard and turning it slower will beat up the air less and create less heat.
In general, ceteris paribus, if you used a bigger blower rather than a smaller blower you will creat more power, more easily, due to the less effort required to supply the required amount of CFM and Boost to generate the power at a lower discharge temperature.
Larger Blower are generally the M112 variety.
Smaller Blowers are M62
Correct Size is M90
Hope this helps.
Regards
Tonsta
__________________
www.v6supercharged.com.au
FIT - Forced Induction Technologies
Home of Australias Fastest and Most Powerful M90 Supercharged V6's
