Quote:
Originally Posted by Tonsta V6 S/C
Hey Darren,
This is the list of recommendations of General Servicing and Maintenance:
1) Change Oil - Castrol R (now EDGE) 10W/60 Fully Synthetic
2) Oil Filter - Standard Holden
3) Fresh Plugs - BPR6EF-13 NGK
4) Replace Air Filter - (or Clean K&N Filter)
Check and top up the following if necessary:
- Trans Fluid
- Power Steering Fluid
- Coolant (Techalloy 90 Recommended)
- Battery Fluid (Distilled Water Only)
- Windescreen Washer Bottle
Extra's for good measure:
A) Cleaning MAF - with CRC Electrical Contact Cleaner
B) Cleaning IAC - with CRC or WD40
C) Top Gun 8.0mm Leads - TG-6165'c'
D) Turn idle up to 950rpm (Intercooled)
Daily Basis Items:
BP Ultimate 98+RON Premium Unleaded (or Mobil Syngery 8000)
Weekly to Monthly Items:
- Tyre Pressures (Approx 36psi)
- Fluid Levels
Long-Term Items:
- Brake Pads
Anything further and beyond this would be better left to advanced mechanical aptitude owners or general mechanical workshops
Hope this helps.
Regards
Tonsta
Hey Tonsta, just wondering - I have a power problem with my VT ecotech - it is only making 150rwhp with CAI, K&N, Hiclone, top-gun leads, iridum plugs, pacemaker headers, 2 and half inch redback exhaust and TBS chip. I have never cleaned the MAF or throttle boddy - could this be the problem? With the MAF is it safe to clean the hot-wire. cheers - ecotec
