Hey,
Just a few questions regarding cooler thermostats in L67 motors.
From my mechanical training years ago... my understanding of the thermostats purpose is to keep the coolant in the radiator long enough to be cooled down sufficiently before being circulated back inside the block. If you take the thermostat out of a motor, the motor will take along time to reach operating temp and then start to overheat.
So what effects do using cooler themostats have on the normal operating temp range ?
Do they make warmups take longer ?
Is the normal operating temp range reduced ?
What is the lowest opening temp that can be run ?
Do they cause overheating in hot weather ?
TIA
