Nope, you'll get zero gains from this mod.
The Stock 65mm MAF doesn't max out till a touch over 300kW, so a Gen 3 75mm MAF won't give any gains if you are producing less than this.
It is CRITICAL to Tune if you swap to a Gen 3 MAF as the calibration of this airflow meter is Dramatically different from the stock MAF.
Either way you will struggle to gain anything from this mod.
Better off looking for the proven performers:
- Boost
- Rockers
- Exhaust
- Extractors
- CAI
... etc.
Hope this helps.
Regards
Tonsta
