Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Sponsors > FIT - Forced Induction Technologies
FIT - Forced Induction Technologies V6 Supercharged Specialists - http://www.v6supercharged.com.au
LinkBack Thread Tools Display Modes
  #1
Old 09-08-2006, 02:10 PM
VN_Luke's Avatar
High On Boost
Ride: VT, RB30ET VN
Trade Rating: (0)
VN_Luke ClubSportVN_Luke ClubSport
Default water injection
Hey just wondering if anyone has any experience with water injection with a side mounted roots blower?
- Optimal placement of water injection?
- expected effects (how much intake temp drop?)
- potential damage to rotor coating?
etc?
just general information would be appraciated..
and also how much more timing can be run with said water injection (as a rough guide) ?
Luke.
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
  #2
Old 11-08-2006, 06:52 PM
WILD VR CLUBBY's Avatar
soon to be turboed
Ride: killa vr
Trade Rating: (0)
WILD VR CLUBBY Executive
i would like to know where the water injection hooks up to is it into the cylinder or in the intake manifold
__________________
R.I.P Peter Perfect!!!!
26/02/1945 to 08/09/2006
We will miss you Brockie
  #3
Old 29-08-2006, 11:44 AM
Supercharged V6 Gemini
Ride: N/A
Trade Rating: (0)
simc Executive
I did a quick google search, a heap of info.
Here is one fella thatknocked one up pretty cheaply.
http://www.dawesdevices.com/howto.html
__________________
BOOSTN
  #4
Old 29-08-2006, 12:19 PM
VN_Luke's Avatar
High On Boost
Ride: VT, RB30ET VN
Trade Rating: (0)
setup's all done already
I used two fuel injectors with a makeshift 'fuel' rail (filled with water @ around 45 psi), wired into the car's remaining injectors and through a hobbs pressure switch so they flick on at boost.
works a treat
  #5
Old 29-08-2006, 03:37 PM
Ride: N/A
Trade Rating: (0)
simc Executive
LOL.. damm ur quick!!
Where did you get the 45psi from? fuel pump?
Power increase?
Get some alcohol in there man
__________________
BOOSTN
  #6
Old 29-08-2006, 10:27 PM
vn6pwr's Avatar
Ride: VN wagon 5spd & 1994 KX250
Trade Rating: (0)
vn6pwr Berlina
Quote:
That would defeat the whole purpose of cooling effect of the water
My dad used to run water injection on his old Dato 200B and from what i heard it had never went better
  #7
Old 30-08-2006, 02:15 PM
VN_Luke's Avatar
High On Boost
Ride: VT, RB30ET VN
Trade Rating: (0)
45 psi comes from high pressure water pump with an inbuilt pressure switch (so no return needed!)
i'd guesstimate and say i can run approx 5 degrees more timing advance with the water injection without pinging
i haven't done a comparison of intake temps before/after yet!
  #8
Old 17-09-2006, 08:21 PM
Matt_vp's Avatar
Ride: vp V6T M5, vy lumina v6 A4
Trade Rating: (0)
Matt_vp Berlina
Any pics of your water injection setup?
  #9
Old 19-09-2006, 01:08 PM
shamus's Avatar
Ride: N/A
Trade Rating: (0)
shamus has disabled reputation
Quote:
alcohol will have a better cooling effect than water......won't it?
  #10
Old 17-10-2006, 05:23 PM
immortality's Avatar
crappy ol' VN driver
Ride: VN3.8 5spd/VSII3.8/VH5.0
Trade Rating: (0)
immortality Malooimmortality Maloo
i've heard a 50/50 mix off water & alcohol works real good, water cools the intake charge and steam cleans the engine (hehehe) the alcohol has the same effect of increasing the octane rating of the intake charge. the combination alcohol/water injection i've sen a few time on turbo cars. one chap i talked to suggested that injecting the mixture directly onto the impeller is the best way to atomise the mixture. this was based on a centrifugal supercharger setup however
__________________
Body by Holden, Soul by Brock
the Legend will live forever
quote of the week
Quote:
Originally Posted by VT-565 View Post
why don't you want to go forshed induckshun?
  #11
Old 30-11-2006, 03:14 PM
Watch this.....
Ride: My "ride"? that's only for Fast & Furious wannabes
Trade Rating: (0)
VT-565 MonaroVT-565 Monaro
Quote:
Water/alcohol mix is good, but the alcohol is not in there as a true octane booster, the alcohol evaporates at a lower temperature than water, in turn, it removes more heat from the intake charge on atomisation.
never aim an injection nozzle at a centrifugal compressor. will cut it to pieces, water is an effective cutting medium at high velocities and this is asking for trouble. ever seen steel barrels cut open with high pressure water jets? very effective. however, if you ensure the mix is well atomised, there is nothing stopping you from placing the nozzle way before the compressor. but most effective position is post-compressor.
__________________
8 cylinders - 1 turbo - All Torque.
  #12
Old 12-12-2006, 05:52 PM
Trade Rating: (0)
Quote:
Originally Posted by EcotecManiac View Post
Water/alcohol mix is good, but the alcohol is not in there as a true octane booster, the alcohol evaporates at a lower temperature than water, in turn, it removes more heat from the intake charge on atomisation. never aim an injection nozzle at a centrifugal compressor. will cut it to pieces, water is an effective cutting medium at high velocities and this is asking for trouble. ever seen steel barrels cut open with high pressure water jets? very effective. however, if you ensure the mix is well atomised, there is nothing stopping you from placing the nozzle way before the compressor. but most effective position is post-compressor.
this guy i talked to had used this setup so it must offworked. don't know about the pressure he was using but from memory he ws using nitrous nozzles and jets to regulate the amount of water/alcohol that was going in.
__________________
quote of the week
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Thread Thread Starter Forum Replies Last Post
water disappearing - water pump - how to change? vh-holden VR - VS Holden Commodore (1993 - 1997) 14 28-07-2008 12:30 AM
Water injection 10000_fists V6 Development And Modification 10 22-04-2007 05:59 PM
water injection on a turbo v6.. hello VP_LUKE... defa V6 Development And Modification 12 03-12-2006 12:28 PM
Intercooling vs water injection VNV6VENGEANCE VN - VP Holden Commodore (1988 - 1993) 4 05-10-2006 09:32 PM
Vk DIY water injection AuWozza VB - VK Holden Commodore (1978 - 1985) 5 02-01-2005 05:20 PM
Xbox Mod Chip |
