| FIT - Forced Induction Technologies V6 Supercharged Specialists - http://www.v6supercharged.com.au |
19-12-2006, 01:33 PM
If it aint blown it sucks
Ride: Supercharged 97 VS Calais
FIT Intercooler Kit on VS Calais
This questions is aimed at you Tonsta! However if anyone else out there can help, please contribute!
Have you ever fitted the FIT intercooler kit to a VS calais, and does the installation differ in any way to the VT?
i.e. will it all fit OK with the different engine bay layout??
__________________
* Yella Terra 10psi Stealth pulley
* NGK BPR6-EF 1 range colder spark plugs gapped to 1.0mm
* 82 deg C thermostat
* Twin cat 2.25" into 3" exhaust
* 3.9:1 LSD, speedo corrected
* 17" wheels with 235/45 Kumho Ecsta KU31's
* Lowered springs
* Blue LED dash & interior illumination
* Sony MP3 head unit, JL Audio splits, monoblock and sub
* Best 1/4 ET - 14.581, 2.003 sec 60 foot time recorded with badly slipping auto. Fully rebuilt with billet servos and stage 2 shift kit coming soon!
22-12-2006, 04:50 AM
Ride: VT CALAIS Supercharged V6
The FIT Intercooler is Universal to fit all L67 Super6 Commodores from VN-VY.
We have fitted plenty to all different models and it's an easy straight forward installation process that takes 6-8hours.
No special tools required, just hand tools, socket set ... etc.
Hope this helps.
Best Regards
Tonsta
__________________
Home of Australias Fastest and Most Powerful M90 Supercharged V6's
22-12-2006, 06:50 AM
Thats great news Tonsta. Another question, is it safe to fit the intercooler and 15psi pulley without a re-tune? I know that the power gains will be far from optimal without a tune but I would like to buy the intercooler kit and then once that is fitted, start saving for a tune.
If this would not be safe for the engine, would it be safe to fit the intercooler but stay at a lower level of boost, say 12psi or even remain on my current 10psi?
__________________
* Lowered springs
28-12-2006, 08:15 AM
Ride: N/A
i have put an intercooler and 17psi on my vs acclaim, i am currently driving around untuned fine, make sure you move the maf to after the charger but before the cooler otherwise you will get some stalling problems.
-steve
28-12-2006, 08:17 AM
Why not after the cooler?
__________________
* Lowered springs
10-01-2007, 01:55 PM
There is too much litreage after the cooler. The Cooler holds around 10litres of Air and backing off the throttle with MAF after cooler results in engine over-run which is although not harmful to the engine, can make it a bit like drive-by-wire throttle annoying to drive.
Regards
Tonsta
__________________
11-01-2007, 07:55 PM
Ride: N/A
so if we buy a A2A intercooler kit for a VS, all the piping will suit the VS engine bay (so its different to the VT)??
12-01-2007, 02:48 PM
Ride: VS S V6 manual ute
Quote:
Originally Posted by AnthsVSLexcen
so its different to the VT??
apparently not...
Quote:
12-01-2007, 03:39 PM
a) does the trans cooler need to be relocated to install the intercooler
b) would it damage my engine in any way to install the intercooler kit and run 17psi without a re-tune?
__________________
* Lowered springs
14-01-2007, 01:06 PM
Ride: N/A
the intercooler is universal but the piping wont be?
15-01-2007, 01:47 PM
a) Yes trans cooler needs to be moved, it's easy to do and illustrated in the instructions provided
b) No it wouldn't damage your engine, just will run and idle a bit rough and not have full power till you get it tuned, but it is still driveable.
If you relocate the MAF it makes it very driveable, just we wouldn't advise to give it anymore than 1/2 throttle.
We would recommend getting it tuned as soon after you intall the cooler for best results and driveability.
Regards
Tonsta
__________________
15-01-2007, 01:49 PM
The piping FIT provide has been purpose designed and optimised to configure to any model of commodores from VN to VY using the one set of standard issue pipes, through clever design and routing it allows for it to fit all these models universally.
Regards
Tonsta
__________________
15-01-2007, 07:59 PM
Ride: N/A
Regards
Tonsta
oh ok, thought it would be different for different models (thats wat iv be told anyways)
thanks for claifying that
30-01-2007, 06:50 AM
