Ive got a hissing noise around the supercharger, most audible on the passenger side around the throttle body. It is also noticable around the driver side also, I am aware that there are vaccuum hoses that run from the fuel line > actuator > around the back of the engine and to the drivers side. Ive looked around at all the hoses (tb/actuator) and made sure theyre on tight and also made sure the purge valve tube is on firmly and also where it goes to the firewall iirc.
Is it normal for the L67 fuel rails to make a small hissing or is there more likely to be a vaccuum leak, even tho there is no error codes? I cleaned TB/IAC about 3 months ago, just replaced the 2 oxy sensors, which braught my fuel consumption from 16.5-17L/100k to 14.5k/100k mainly 90% suburban/city driving. But i jsut dont wanna be losing ~2L/100k for a tiny leak
