Results 1 to 4 of 4
Thread: Switching from Petrol to Gas
    VY II Executive
    May 2009
    Default Switching from Petrol to Gas
    Hi all, I'm new to driving a duel fuel car and I was wondering which is better.
    - Rev up to 1,500rpm, then switch to Gas while stationary;
    or
    - Do the same as above, but while in motion.
    I've done a combination of both, but I just want to know which is better and which procedure you do on your car.
    Thanks
    Ado's Avatar
    Ado
    Ado is offline Are we there yet?
    vsII statesman L67
    Apr 2008
    VL V8 & supercharged VX
    Nov 2006
    western vic
    yeah try and get a switch with 3 settings 1 for gas on 1 of cut off fuel and 1 for fuel..
    so if u start it on fuel then switch the pump off with the 2nd setting then wait till it cuts out then switch it straight to gas then fire it up no probs..
    or if u want to run it on gas most of the time and its hard to start up in the morning.
    run a primmer button on ur dash. then it primes the gas then it will fire up..
    hope this helps ive been doing gas for a while now had a dual fuel setup but converted it to straight gas..
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Either of the methods you've suggested is fine. I would just be inclined to try each method several times to see which seems to work best with your setup and then just stick with that. When I drive a car on gas I tend to do it while moving.
  1. Switching from Gas to Petrol problem
    By taylorb100 in forum Electrical Wiring / Questions
    Last Post: 27-08-2009, 04:16 PM
  2. Switching Languages
    By R Photon in forum The Pub
    Last Post: 08-05-2007, 11:00 PM
  3. Switching exhausts
    By [JUDGE] in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-03-2007, 01:06 PM
  4. quick question about switching from gas to petrol
    By JD in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-10-2006, 04:39 PM
  5. Abs is switching off
    By robbie77 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-09-2006, 10:19 PM
