Results 1 to 12 of 12
Thread: performance chips, paint?
    AgE_vs's Avatar
    AgE_vs is offline Age
    v6 vt berlina supercharged
    May 2009
    Question performance chips, paint?
    hi yall, ive got a stage 4 performance chip in my ecu and another in the air flow meter should i have them both in? i also wanna get a paint job my vs is currently white im thinkin i want it black does any1 kno roughly how much it mite cost me? or even 4 a white respray?
    HoldenManDan's Avatar
    HoldenManDan is offline Built, not bought...
    VS Exec SII 4.2L L67 T56 :D
    Jul 2006
    Penrith, NSW
    out of interest, what "chip" is it you have installed in the AFM? I hope for your sake it wasnt one of those $20 ebay "chips"! And what stage 4 chip have you got in the ecu?
    Umm closed door respray in same colour will set you back around $3500 - $4K from a decent shop, a bit more if you were to change colour ie more places to paint...
    hope this helps
    Factory 5 speed VSII, now 4.2 Litre L67 with T56 6 speed
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Where the HELL is "stage four". That's what I want to know rofl
    May I kindly suggest that OP throws out these "chips"?
    The 1972 HQ Kingswood
    AgE_vs's Avatar
    May 2009
    yes the chips were brought off ebay, i got told they were the way to go? not sure which stage performance chip in my ecu is call just ses stage 4 perfomance? what should i do? whats op? i have **** all knowlage about cars
    Sabbath''s Avatar
    Sabbath' is online now Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    OP is Original Poster. Being, you.
    Performance Chips on the whole arent usually the way to go to seek reliable performance. Cars pulling big numbers, or even cars just running sensible street figures dont do this with chips from ebay.
    The best place to start modifying a car is to have a look at where you want to go with the car and work from there. Just slapping a chip from ebay that says "Stage 4" on it isnt a good way to do it. What is stage 4? So many companies use "Stages" as a way to teir their products, but what scale are they basing it against.
    Oh, and chips off ebay have been covered a few times here and the general consensus is to steer clear.
    vs ute
    Sep 2008
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    shit he put his prices up LOL greenfoam does em for $50 and postage and are way better hehe
    Trayner's Avatar
    Trayner is offline L337
    1996 Vs Commodore Acclaim, 1996 Vs Commodore Ute
    Aug 2008
    Lol! he says that in his own add?
    WARNING:
    When making the decision to purchase performance chip for your car we recommend that you carefully consider your options. We recommend that you be wary of:
    The mod chip – this is simply a cheaply priced, small resistor fitted to a temperature sensor in order to trick the system into thinking that it has a lower? Engine temperature than it really does. In turn the engine management system makes adjustments to the fuel system accordingly. In most cases this adjustment is to richen the system or to lean it. This is a cheap and nasty shortcut, it does not work correctly and is dangerous to your engine. Buyers should not trust any modification that tricks the engine management system rather than programming the parameters correctly.
    The eprom – these are cheap IC units that are available in any hobby store. An eprom is recognisable as it comes without a carrier or a cover and needs to be re-soldered into your standard chip. They are reflashed using mostly copied programs that are freely available to download from the internet. In most cases these are copied programs that are generic to a wide range of models rather then being specifically programmed to suit a particular model. As one chip does not suit a wide range of models but must be programmed specifically according to the model, we recommend that buyers again be careful if planning to make such a purchase. If a seller is selling many eproms for many different makes/models then you can be fairly certain these are the copied programs to which we are referring. The cost and difficulty of de-soldering your current eprom and ther re-soldering the new eprom will usually end up costing more than to simply buy a custom performance chip and plug it in. One must also consider that the risk of damage to your car's computer by installing the eprom is very high. Buyers will naturally find that the stated power gains will not be achieved. In short, buyers will get what they pay for - very little or even worse, costly repair bills down the track.
    VP Executive R-spec
    Jan 2005
    I was going to talk about Blackstar but I suddenly felt sleepy from the bordem of it all ?
    в∞ѕтεכ √&
    Jul 2008
    NZ
    haha he has the most bullshit sales pitch on there
    Jun 2005
    lol considering his whole little rant on eproms is basically the same thing as he sells
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
  1. performance chips?
    By Summer-Sickness in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-03-2008, 12:03 AM
  2. Performance Chips
    By hindred in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-04-2006, 09:19 PM
  3. Performance Chips
    By Haze in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-02-2006, 07:50 AM
  4. performance chips
    By webwombat in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-08-2005, 02:12 PM
  5. Performance Chips :
    By MattK in forum V6 Development And Modification
    Last Post: 01-05-2005, 02:38 PM
