just wondering if a t5 out of a ford eg. ea eb ed will bolt straight up to a vn ?
need to know asap thanks
The Less Traction, The More Action
While yes it will bolt up to the bellhousing, you will have issues with the input shaft.
The input shaft on the Ford T5 is a different thickness and won't fit the Holden clutch plate (I found out the hard way, about 1/8 an inch difference). Chances are the input shaft is also a different length as well.
Hot Lap Motorsport
Thats correctThe ford T5's ran a different input shaft. If you can source an input shaft from a holden v8 (or a v6 and have it shortened) you should be able to swap it over, but they're pretty hard to come by these days without buying a complete box and the new repro input shafts are well over $500 from memory.
Ford T5 to Holden bell = Ok
Ford Bell to Holden block = Fail
Ford T5 input to Holden motor = Fail
Overall Ford T5 to Holden = Fail
Reaper
