Results 1 to 3 of 3
Thread: Heat Wrap, Anything i should know?
    SMIT's Avatar
    SMIT is offline Donating Member
    VT C2R TURBO 5SP + CRUNCH VE SSV 6SP
    Aug 2005
    Mornington Peninsula, Victoria
    Default Heat Wrap, Anything i should know?
    Hey guys,
    Two of my spark leads are melting on my turbo side manifold, someone suggested i wrap the manifold in heat wrap rather than trying to get some spark leads that would fit better.
    Now, is there anything i should know?
    How many mm wide is good?
    How many mm thick should i get?
    Would 10m be enough on average for one manifold?
    Anything else i should know?
    Here's what im looking at on ebay:
    Ebay link
    Thanks for your help in advance guys
    vn calais, vs clubsport #137
    Jun 2005
    faroogoo's Avatar
    faroogoo is offline SENTINEL
    GMH
    Nov 2006
    S.A
    Also get hold of some heat protective sleeving from Pirtek(& probably other fitting stores) Its orange rubbery coating on the outside & a fiberous coating on the inside.
    Heat wrapping works also just dont wrap it too thick near where it bolts too the head,High performance coating(jet hot,HPC etc Give Yourself The Competetive Edge!) would be better though.
    The sleeving worked wonders on my ex turbo setup,cant remember how much it was around $50-$70 a metre i think,but it ends up being cheaper than new custom length leads every 2 months.
    "If you're going through hell, keep going"
  1. Header/exhaust wrap questions
    By ucwepn in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-03-2006, 10:39 AM
  2. Cling Wrap Peeling Off My Car...
    By holden#1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2006, 06:57 PM
  3. header and engine pipe heat wrap
    By blofly in forum V6 Development And Modification
    Last Post: 25-07-2005, 07:05 PM
  4. Bubble wrap
    By Troy711 in forum Jokes/Humour
    Last Post: 01-05-2004, 01:46 PM
