Results 1 to 3 of 3
Thread: am i forgetting anything for a v8 conversion
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    Default am i forgetting anything for a v8 conversion
    got a 5 speed v6 vp exec, and i'm bidding on v8 conversions on ebay, just want to know if i've included everything i'll need
    airbox top (think this will mate with the airbox bottom i have)
    shroud
    radiator &fans
    engine
    gearbox/clutch
    loom
    headers
    exhaust
    ignition gear (coil?)
    tailshaft?
    computer/memcal (if it's newer than vp i'll need a computer, otherwise not)
    kframe and mounts
    1" master cylinder/bigger booster
    dash
    do i need to do anything with the fuel pump(s) or front suspension? will the pedal box and cruise module i have be ok?
    pow3rslave is online now Report Post Edit/Delete Message
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Are you VP series two? Just curious if you hvae V8 brakes standard. Suspension is technically different, but you should be fine.
    Sounds to me like you'll have pretty much everything you need.
    The 1972 HQ Kingswood
    pow3rslave's Avatar
    VP 5.0L
    Oct 2005
    eastern subs, vic
    pretty sure i'm s2, got finned fronts, but the Master cylinder isn't 1"
  1. vu to vy conversion
    By Conn in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-01-2009, 04:45 PM
  2. ve sv6 lpg conversion
    By yogles in forum VE Holden Commodore (2006 - ?)
    Last Post: 11-01-2008, 08:44 PM
  3. conversion people conversion
    By flynn84 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-09-2007, 01:25 PM
  4. Forgetting Sump Washer
    By Shounak in forum General
    Last Post: 30-12-2005, 03:14 PM
  5. Vp manual conversion and vn auto conversion
    By gumbs in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-06-2005, 11:08 PM
