Results 1 to 24 of 24
Thread: welding my diff
    Perth_5.0_Man is offline Please Pimp my ride
    Vs Berlina 5ltr/Vp exe 5ltr
    Feb 2009
    Default welding my diff
    im just after any info on this its not a street car just a thrasher
    eaton v8's Avatar
    eaton v8 is offline my little sleeper
    vz 6l auto 239cam 3.9diff
    Jun 2008
    gladstone qld
    Matt_vp's Avatar
    Matt_vp is offline Donating Member
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    attach earth and stike the arc.
    Matt
    VP TURBO WAGON --13.04 @109mph >>>>>http://forums.justcommodores.com.au/...-vp-wagon.html
    Never tell your problems to anyone...20% don't care and the other 80% are glad you have them.
    - Lou Holtz
    Found my reply helpfull? Share the love and click the star down the bottom
    Vy Sv8
    Jun 2009
    I think he means where to weld??
    This might be a good idea for my gemini haha.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    You weld the spider gears to the shaft so they don't turn independently.
    Visit my Facebook page
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    azzfox's Avatar
    azzfox is offline slideways
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    Hahahaha at top pic^ I almost pissed myself when I first saw that and read the owner stuffed the clutch trying to take off
    My (ex)Ride
    Quote Originally Posted by ari666 View Post
    LMAO!!! bracelets!!! and neck chains?!?!? they are as gay as aids.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Nice 4 year old thread dig dude....got a permit to mine that deep?
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Didn't your mate do that as a joke? You posted that a while ago....funny stuff but.
    VXII SS M6 & Leather
    Nov 2003
    Warrnambool
    Quote Originally Posted by azzfox View Post
    are you serious?
    care to explain how you would even get that back into the diff housing to start with?
    the whole thing was a prank from start to finish.
    Jesterarts's Avatar
    Nov 2005
    Mornington, VIC
    Yeah... pretty sure it was a prank... I just remembered seen the image and thought I would pinch the pic to demonstrate how to do it right and wrong...
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    Quote Originally Posted by davway View Post
    are you serious?
    The pics I saw was also in the diff housing, and then the one as above with it removed. You could easily get that back in the housing if the pinion is welded in the correct position. The pinion would slide back into place then tighten the carrier bearings, no?
    If it was a joke then I just died a little inside.
    My (ex)Ride
    Nov 2003
    Warrnambool
    Vy Sv8
    Jun 2009
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
  15. #15
    Wagon_Wheel's Avatar
    Wagon_Wheel is offline Drop A Patch....
    Aug 2005
    Mt Martha, Vic
    Depends how good you weld it.... and how much crap you give it. Ive seen dudes run welded diffs for years. I got one of my diffs welded in my old sigma turbo and it lasted 2 weeks
  16. #16
    vs III commodore ute
    Sep 2008
    hahahaha i was looking at the first pic and was like how the *** dose that work... then i seen the fail... DEFS a FAIL!
    Quote Originally Posted by Jesterarts View Post
    = FAIL
    = SUCCESS
    My CaR dOsNt ChErP gEaRs, It JuSt KiCkS sIdEwAyS!
  17. #17
    Sep 2008
    ps... just get a mini spool for 80buks i found it easyer just to stick that in
  18. #18
    VZ 3.6 V6 Berlina Auto
    Oct 2008
    Central Coast
    I've got some mates that decided to weld their diffs. (bit tight on cash)
    ones a manual V6 VR
    the other an auto V6 VS
    the manual one's broke an axle (not sure on specifics, just know his up for a new one)
    why would the manual one be more susceptible to breaking, if they did an almost identical process to both??
    has it got to do with the dumping of the clutch?
    thanks
  19. #19
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Manuals are a direct drive while in an auto the torque converter and the box itself absorb a lot of the torque from the engine.
  20. #20
    dirt drifter's Avatar
    dirt drifter is offline white trash hillbillie
    VS 5L M5 VS 6L M6
    Apr 2009
    massive hole in the ground
    i knew a bloke who welded the diff in his HX monaro, drifted round a corner and one of the welds broke off and got jammed solid betwen the crownwheel and pinion. tried going forward or reverse it wouldnt free up, stuck on a main road in arvo peak hour blocking 2 lanes until a mate showed up with a fourbie to tow him off the road. had to drag this thing backwards 50 odd metres until it spat the weld out and freed up. wouldnt have had that problem if a $100 mini spool went in there in the first place
  21. #21
    VN SV3800
    Sep 2008
    padrickz88's Avatar
    padrickz88 is offline Rick =]
    VN V6, nothing special
    Dec 2005
    sunshine, melbourne
    Quote Originally Posted by sv3800#055 View Post
    dangerous and almost impossible to reverse your car with
    locked diffs are perfectly fine at reversing? people say there a bitch to reverse park but i personally find it pretty damn easy
  23. #23
    VR HSV Clubsport
    Jun 2008
    Hobart,TAS
    Quote Originally Posted by padrickz88 View Post
    ....But the clunking/squealing can get a little annoying at times...
    Tasmania....Coz 2 heads are better than one...
  24. #24
    padrickz88's Avatar
    Dec 2005
    sunshine, melbourne
    believe it or not, i've actually noticed (on my car) there is less skipping when i reverse park
    weird but true
  1. welding?
    By Peter89 in forum General
    Last Post: 12-04-2009, 01:04 PM
  2. TIG Welding
    By Wrayza in forum General
    Last Post: 22-12-2006, 08:01 PM
  3. welding
    By vicarious in forum The Pub
    Last Post: 02-11-2006, 06:34 PM
  4. defective welding
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 24-07-2006, 04:44 PM
  5. welding??
    By V3N0M in forum General Discussion
    Last Post: 17-06-2006, 01:29 PM
