Results 1 to 11 of 11
Thread: TE Magna injectors in VN V6?
    VK Speedway
    Jul 2009
    Riverina NSW
    Question TE Magna injectors in VN V6?
    G'day guys. Have been told that fitting the fuel injectors from a (V6) TE series Magna (or similar) is a good way to improve the fuel delivery to the VN-VP series motor. These have a higher flow rate (apparently) and are a simple installation. Apparently a similar injector was used in the VN GRP A SS.
    Economy is not a problem as the car is used on the race track. Has anyone else done this or have a similar idea? Am new to this forum and would love to hear your comments.
    VP Executive R-spec
    Jan 2005
    There the blue 775 and cream 706 injectors in the Magnas they were used in the 5.7 litre Holden V8 and the Group A, but there's no advantage to running them in a speedway V6, since you will be running too rich and end up slower
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    i got a question, will the v6 magna injectors fit into the 3.8 vs v6? and is there any real gain from doing so?
    CANYONERO's Avatar
    CANYONERO is offline Likes Cheese...
    V8 6spd wif MOMO leavaa.
    Mar 2006
    Country SA
    VK Speedway
    Jul 2009
    Riverina NSW
    Quote Originally Posted by greenfoam View Post
    thanks greenfoam. will chase down some other performance mods. I guess there is the option of replacing the memcal chip to an after market brand to cope with the extra fuel. Would this work O.K. in your oppinion?
    VP Executive R-spec
    Jan 2005
    Yes that will work but then you are jsut back to where you started, You can't make a standard motor need the fuel the stock injectors can supply so there's no need for bigger ones. If you want to bend the rules a little on a speedway car where you need to run a standard tune then you can slot the crank sensor and rotate it a few degrees for some more timing
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Quote Originally Posted by DVSV8 View Post
    why? and probably not. but dunno.
    i was just curious, i heard a mate talking about them
    Vp Commodore S2 5 Speed
    Jun 2008
    i got pacemaker headers and magna injectors in my vs.. it goes a fair bit better than stock.. but that may be the headers alone
    VS commodore series II
    May 2010
    North Queensland
    i have a CAI and cat back zorst on my car, and once i put the magna injectors in there was a slight gain in my VS
    vr x cop
    Nov 2009
    VR Brolina 3.8 Turbo
    Aug 2008
    Wellington, New Zealand
    Yes, but as allready stated, they're going to make your car run worse. You need a tune to suit, and even then, it's not going to give you any added performance, unless your old injecotrs were rooted.
    R.I.P dynoryder
  1. [VIC] FS: 99 TH Magna V6
    By lad79 in forum Vehicles For Sale
    Last Post: 10-02-2009, 07:52 PM
  2. Magna injectors, flow rates, and models to fit vn v6
    By Bz Kn33z in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-01-2009, 07:47 PM
  3. VR/S HSV CAI & KN FILTER, 8x magna injectors 26lbs
    By sir355 in forum Parts And Other Items For Sale
    Last Post: 21-12-2007, 05:35 PM
  4. Magna injectors
    By andynogo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-01-2007, 04:32 PM
  5. Magna Vs Camry???
    By Shivaga in forum The Pub
    Last Post: 14-09-2005, 05:30 PM
Tags for this Thread
