Results 1 to 6 of 6
Thread: RB25 Head On A RB30 Block, How Hard?
    lkrrepz is offline KiCkN dA ClUtCh AlDaY
    VL RB30
    Mar 2009
    Bowen Whitsundays North Queensland Australia
    Default RB25 Head On A RB30 Block, How Hard?
    Ive Herd Of People Putting RB25 Heads On RB30 Blocks. How Hard Is This?
    I No It Ill Be Better, RB25 Being A DOHC,
    Is There Much Cost Invold? Is It Plug And Play?
    Anyone Know Cheerz Guyz
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    you have to change the pistons to fit head on due the the multivalve setup of the twin cam heads but otherwise it bolts up fine
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    Vu Spac Ute
    Mar 2009
    Nazza Wazza North
    i stole this info, from classicskylinesaustralia
    Tap a hole the block for a timing belt tensioner
    Gates make a timing belt to suit
    RB25 NA pistons, for decent compression
    All the usual block prep when building a fresh motor
    Shave the head a tad for more compression
    RB25DE Head (from R32-No VCT)
    May need some oil restrictors in the head, they can flow too much oil and the head fills up with oil.
    Remap an RB20 ECU or Nistune/PowerFC/other aftermarket ECU
    Can use a later R33/34 head, you will either need to run an external oil line to run the VCT,
    or weld the oil galleries in head and block it off - no VCT though - good thing to have particularly for NA application
    RB26 head will work too - no VCT to worry about.
    If you want VCT the R34/NEO head is best, gonna be pricey though, and I've never heard of anyone doing it. Should be pretty same same though.
    "your gayer than a treeful of monkeys on nitrous oxide"
    Statistics show that 90% of all commodore accidents happen right after the words "Watch this bro!"
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    Nzpure's Avatar
    Nzpure is offline VS L67
    1997 Vs Supa6
    Aug 2008
    Christchurch
    They do it in NZ heaps to make rb30det & rb30dett which is rb25de head with rb30e bottom end or rb26dett head an rb30e bottom end
    Rotorua Import Pro Shop R.I.P.S
    those guys make a living off building them heaps of info there
    Steery's Avatar
    Steery is offline AA 554 G
    94 VR SS M5
    Feb 2008
    Adelaide, near Cross Road Maccas.
    It is not uncommon at all for this to be done, popular in Skylines and VL Turbos. They do this instead of dropping a RB25DET in generally because they are looking for big power and the RB30 turned twin cam is the best option for this due to the larger displacement.
  1. Rb20, Rb25, Rb26, Rb30..... ?
    By Marco-EFIVL in forum Straight 6 Development And Modification
    Last Post: 30-12-2009, 12:40 PM
  2. rb25 head on rb30
    By starfire vc in forum VL Holden Commodore (1986 - 1988)
    Last Post: 15-03-2008, 09:57 AM
  3. rb25 head worthwhile?
    By bangers in forum VL Holden Commodore (1986 - 1988)
    Last Post: 08-01-2007, 05:48 PM
  4. rb25 head
    By kunifa in forum VL Holden Commodore (1986 - 1988)
    Last Post: 20-03-2006, 11:04 PM
  5. Rb25 Head On Rb 30
    By \\SaM// in forum VL Holden Commodore (1986 - 1988)
    Last Post: 05-04-2005, 01:33 PM
