hey fellas
i own a vy ute with a v6 eco tec in it. i just put twin throttles on and started the car although the car idles at 2300rpm. has anyone had this problem, is there any way to fix it.
could it be a tune? is there anything i can do to fix it from here. and if it needs a tune is there any one that will tune a v6 ecotec
thanks
chris
yeah but im still on p plate laws so yeah. the motors still stock all its got is a pod and injectors and sports exhaust
Sports exhaust as in... makes a good sound but no performance gain or you at least have extractors as well. Not having a go or anything but so far you have nothing in that car that gives you any extra KWs. The pod is probably deducting some KW too.
The best advice anyone can give you mate is if you leave that car stock on your p plates and save the money up for something worth while like a turbo or selling this car in combination of the saved up money buy yourself a V8. Thats only if you are looking for a faster car, otherwise keep the V6.
Just my opinion really.
yes but the thing is mate, i came on here to ask why my car is ideling at 2500rpm not to get advice on what to do, and to get criticised. i have another car thats anonomys to this convo then you will realise that im not just another dick with a 3.8 litre bommodore thats lowered in the ass on stockies and i think im mr brock
nah but now what i did was i disconnected the battery hoping that the computer will reset it self
where did you get the twin thtottle body manifold from or is it a custom job? also what throttle bodys are you using?
Check out my ride here >>>>My VX Raptor
say NO to chev badges
Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
What did u do with the second iac valve?
Got any pics?
need more info if u want help, it could be a number of things.
Matt
VP TURBO WAGON --13.04 @109mph >>>>>http://forums.justcommodores.com.au/...-vp-wagon.html
Never tell your problems to anyone...20% don't care and the other 80% are glad you have them.
- Lou Holtz
Found my reply helpfull? Share the love and click the star down the bottom
Sounds good good luck with it!
sorry just read you havind problems
hey man i'm no expert about your problem but try fiddling with you throttle cable it may be still set up for a single throttle body, try loosening the cable and see if the rev's drop down. good luck by the way mate
Which TB is the TPS on? You will need a tune most probably because the computer will take a reading from one TPS and it has no way of detecting a second TB.
Also, the most common issue that throws the RPM out when changing TB's on v6's is forgetting to put the little, black plastic adapter in with the TPS.
Read post #19:
URGENT HELP please motor reving to high
Also, since you have 2 TB's its like having one TB open twice as much as the TPS is sensing.
Eg.
[ I think]
You open the throttle 1/8 of the way... in a normal situation, the TPS detects this, sends the message to the PCM and the PCM adjusts the IAC open just a touch to keep the rpm smooth and running as it should.
But you have a second TB, so you have 2 TB's open 1/8 of the way PLUS the IAC open a bit like it would be with a single TB open 1/8... so heaps too much air getting through.
[ / I think]
There has been a couple bokes on here that went the twin TB way and had to get tune calibrated to them...
Good luck.
PS, check the TB's are closed all the way when it's idling...
this is very LOLZ.
i cammed my super6, started and idled at 800rpm straight away.
twin throttle will cause you to lose lots of resolution. you are effectively halving the available tps stepping...
what has camming your super6 got to do with twin throttles, but thanks for throwing in your knowledge from your lack of experiance. No help at all. So yes it will need to be tuned to suit the 2nd throttle. Even though when i put mine on, the only problem i had was high idle so i reset the iac valve and jackpot, perfect idle.
Matt
- Lou Holtz
LOOK AT MY TWIN THROTTLE.I NO ITS NOT A ECOTEC BUUT STILL. IT MAKES DIFFERENCE,BUT NOT AS MUTCH AS THE BLOWER
