Results 1 to 3 of 3
Thread: Creaking Sound From Throttle Body
    VT Commodore Wagon V6
    Aug 2009
    Exclamation Creaking Sound From Throttle Body
    I am in the middle of diagnosing if the battery, or the starter motor is gone. i am hoping its the battery.
    When i turn the ignition to the "on" postion, i here the fuel prime and a slight creaking noise. When i turn the key back to "off" it creaks back. Later i identified the noise to be comign from the throttle body.. switch/soliniod jamming??? i doubt its normal? 207,000kms
    Any clues anyone???
    vt1538's Avatar
    vt1538 is offline 455rwhp LS3
    VY SS S2 11.284@125mph
    Sep 2005
    The Dead Centre
    That is your Idle Air Control stepper motor moving into position. When the key is turned on it moves to a point set in the tune. Key off it moves back to the park position.
    FWIW it shouldnt be making a creaking sound, more of a ticking noise as it "steps" the pintle out. There is a chance that that it is gummed up causing the creak, a quick clean should fix this.
    Changa is offline Alex Short
    VS Executive
    Jan 2009
    Hervey Bay, Queensland
    ^^ above comment is true I found this noise and thought it was not normal, but I am fairly sure it actually is. I thought it was the cruise control motor started or something to do with the cruise control anyway.
  1. Vt V6 hissing sound under light throttle
    By muso in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-11-2011, 08:51 AM
  2. VS Problem sound diagnosis, rear creaking/knocking
    By Kingo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-08-2009, 11:27 PM
  3. Air Intake / Throttle Body Sound
    By Noel-e in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-05-2009, 10:34 PM
  4. creaking sound at the rear wheels
    By mick-888 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-10-2008, 09:35 AM
  5. XF Throttle body for VL
    By bangers in forum VL Holden Commodore (1986 - 1988)
    Last Post: 09-09-2005, 08:35 PM
Tags for this Thread
