Results 1 to 23 of 23
Thread: How much RWKW would a Stage 3 Engine give me on a 1993 series 2 VP V6
    Vp Commodore Series 2 GROUP A SS MOCK
    Jun 2009
    Default How much RWKW would a Stage 3 Engine give me on a 1993 series 2 VP V6
    How much RWKW would a Stage 3 Engine give me on a 1993 series 2 VP V6?
    would like to know as my car is stock and at the moment is has about 85rwkw and 125fwkw would like to know how muck fwkw and rwkw power i would get with a stage 3 engine rebuild
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    Jun 2009
    whole engine rebuild maxed out to what it can hold hope more than 150rwkw
    cams, heads, rockers u name it
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    The problem is each company have different stages.
    One companys Stage 3 could have less than anothers stage 2. You really have to specify the company and the parts they'll be using.
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    Blown V6 Hatch's Avatar
    Blown V6 Hatch is offline Too many projects.....
    VN Calais 5.0, UC Torana hatch 383, WB Ute 5.0
    Jun 2005
    Cowes, Phillip Island
    TVR-190's Avatar
    TVR-190 is offline SkyFall
    WK Statesman LS1
    Jun 2008
    Sutherland Shire N.S.W
    VP Executive R-spec
    Jan 2005
    You can make 150 rwkw out of a VP V6 no problem, but it will cost you twice as much as much or more than just going and buying a complete 5 litre car which will also have twice the torque in the mid range once you have gone that crazy on your V6
    Jun 2005
    I don't understand what the fascination is with trying to build a fast N/A V6? It's a complete waist of time & money, Just boost it up and be happy....
    VP Executive R-spec
    Jan 2005
    Can't argue with that . Better still throw it in the bin and but a RB30 in it, then you can have power and legal (ish). The very fastest NA V6's are only in the high 13's best case and it's just not worth spending all those dollars to get there
    Jun 2009
    i wana keep my v6 but to do an eight it would cost more money converting it, i know just buy an 8 instead of swapping it into the 6 but the car has sentimental value,
    so u guyz think maybe i should just supercharger her and ill get the power that way or rebuild the engine with stage 3 componets and super charger.
    couple years down the track i wana have her as a show car really..
    i have 5,000 to spend what do u guys think i should get done to the engine
    P.S i also wanted a stage 3 engine coz the engine has done almost 350,000kms and the guys at the auto shop said its pointless putting a stage 1 or 2 cam in coz the engine is old so u might aswell just rebuild her,
    ne replys would be great cheers.
    STEALTHY™'s Avatar
    Jan 2005
    Once again, stages mean nothing if you don't list what parts it comes with
    cheers sexy
    Jun 2009
    yeh true when i know the brand name ill let u know do u have ne work done to urs?
    vs berlina 5spd wagon black
    May 2009
    padstow sydney
    hey walker i had a worked vn v6 and it went great.great motor and transsmission.3.55 in the diff.the drive train was bullet proof and never had a problem with it. although,for the money spent i could have built a 355.
    cooks food for a living,frys tyres for fun
    May 2009
    padstow sydney
    is this somthing what you were looking at or were talking along the lines ofhttp://cgi.ebay.com.au/holden-vn-vp-vr-vs-v6-stage-3-performance-sre-engine_W0QQitemZ120462339806QQcmdZViewItemQQptZAU_ Car_Parts_Accessories?hash=item1c0c1d6ede&_trksid= p3286.c0.m14???
  15. #15
    deathsminion's Avatar
    deathsminion is offline Chrgd,Coold,Twinthrot'in
    GT42R forced JZA80 Supra and VT Wagon
    Oct 2004
    That engine wouldn't make much more power than a cammed VR V6. Same SCR, no flow figures, a drop in clive cam with uprated valve springs.
    ****ing crooks.
  16. #16
    Jun 2009
    IBT18U yes thats the sort of motor im after roughly 150 RWKW i wana stick with a my VP V6 coz my car has sentimental value althought id like to get a V8 instead,
    but do u think its worth it in the long run as i will have her for a very long time
  17. #17
    Troy5L's Avatar
    Troy5L is offline building a lemon
    Blown VS Clubsport, Hektic Bravo ute
    Jun 2005
    Mornington peninsula
    as i said in the other thread, just whack a turbo on it and you will get a great increase in power
    Vortech V1 supercharger : 10psi : Intercooled : 3.89 Mini-spool : VT Big Brake conversion : Shift kitted auto : B&M Shifter
    My VS CLUBBY!
    237.2RWKW - 318.1HP - 926.4 NM
    Quote Originally Posted by ari666 View Post
    "putting additives in your oil is like putting things up your bum.... to some people its the best thing in the world, but to me its the most horrid thing i coud possibly imagine"
  18. #18
    Jun 2009
    yeh but adding a turbo or super charger on a stock motor will put strain on the motor wont it?
  19. #19
    shiftySLE's Avatar
    shiftySLE is offline The Lion will never Die!
    VH SLE, VZ Acclaim
    Jun 2009
    does the car have sentimental value or the motor, could you not buy a 5.0 and do the transplant, you'll end up with more power straight away and it would easy to get work done on the motor while its out too.
  20. #20
    Jun 2009
    the car has sentimental value, how hard is it to put V8 wiring in what else would i have to change like computer, brakes optional and so on
  21. #21
    shiftySLE's Avatar
    VH SLE, VZ Acclaim
    Jun 2009
    nothing is hard if you have all the right parts, thats why i say source another car that has been smashed in the back or side, anything you need is there, look up conversions and have read and weigh it up as an option. I had my whole engine bay on the last car rewired to neaten it up and that only cost $350. When it comes to electrics, i like getting the pros to do it.
  22. #22
    Jun 2009
    Aug 2004
    moderate boost on the engine and you will be absolutely fine. i was fine on 15psi. raised it to 17psi and blew a headgasket. but even then that was all.
  1. 1993 VP Wagon 3.8 Auto Seized Engine
    By BlondieMc in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-08-2009, 08:56 PM
  2. JD's 1993 VR Executive (Series I)
    By OzJD in forum VR - VS
    Last Post: 27-03-2009, 05:51 PM
  3. stage 2 performance engine which oil and to gas???
    By spunkykpc in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-09-2008, 06:55 PM
  4. Replies: 5
    Last Post: 16-11-2007, 12:32 PM
  5. 1993 VR Funny engine vibration
    By davo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-08-2005, 07:27 PM
