Results 1 to 2 of 2
Thread: Coolant system question
    '01 VU Ute, Manual 5.7
    Nov 2008
    Default Coolant system question
    hey, how does the coolant system warning light know when to come on. does it measure the pressure level in the system; so if theres a leak the pressure will drop and the car will know the level is dropping?
    cheers
    VT Exec 5.7
    Jan 2009
    From what my VT has, it comes on when the level drops in the reservoir bottle.
    There is a sensor in the base of it.
    You could assume this is carried on until the VZ's when they did away with the reservoir.
    *edit* Just to lead on from this, if you have noticed a drop in your levels, check the plastic end cores of your radiator for leaks, extremely common. They tend to crack around where the hoses connect to the top/bottom of the core.
  1. vx v8 coolant system
    By andrewcut in forum General
    Last Post: 18-04-2009, 07:17 PM
  2. Coolant system overfilled
    By Flat_White in forum General
    Last Post: 14-07-2008, 10:15 PM
  3. Oil in coolant system
    By marco2768 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-02-2007, 09:52 PM
  4. Bleeding coolant system
    By coolvxss in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-12-2006, 05:25 PM
  5. How Would I Go On Flushing My Coolant System?
    By r_i_d_a_h in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-12-2006, 01:32 PM
