Results 1 to 10 of 10
Thread: Help with possible cooling system air lock
    VN 5ltr Calais
    Oct 2007
    Werribee, VIC (Westn Subs)
    Default Help with possible cooling system air lock
    Hi guys, I have a VN 5ltr and I took the radiator cap off the other day to suss out the coolant and ever since it's ran hot and taken ages for the thermostat to open. Today I flushed the cooling system and replaced the thermostat and coolant and I still have the same issue. The radiator cap remains cold too.
    What's wrong? If it is an air lock how do I fix it? It's shittin me bad now!
    nemesis_adrasteia's Avatar
    nemesis_adrasteia is offline better to reign in hell
    VR accliam, TF gemini, TC gemini, 79 isuzu ute
    Feb 2009
    longford, victoria
    did you bleed it properly? can take a fair while to get all the air out.
    "The mind is its own place, and in itself, can make a Heaven of Hell, a Hell of Heaven."
    apparently wasting my time with 97 cubic inches
    milk doesnt come in 1.6 litres
    my geminis
    VN 5ltr Calais
    Oct 2007
    Possibly I haven't bleed it properly I'm not sure, I've never had this drama with any of my cars before. What's the best method for the Commo?
    dynoryder is offline Banned
    vp executive wagon
    Oct 2009
    A.C.T.
    you should turn the engine on wait till the thrmosat opens then pour more water in then keep an eye on the level for a few days a good rev for a min or so will get air out too
    VN 5ltr Calais
    Oct 2007
    Seems to have settled a little, it's consistantly 1/3 temp on the guage now rather than well over 1/2 which isn't too bad for idling in the driveway I guess. I'll take it for another run after Bathurst finishes and hope to hell it doesn't overheat.
    VN 5ltr Calais
    Oct 2007
    Took it for a drive and it seems to have settled but I'll see how it goes going to work tomorrow. The car had a 192F thermostat and it used to sit well under 1/4 temp so I changed it to a 195F hoping it would bring it up to 1/4 temp but now it seems to even out half way between 1/4 temp and 1/2 temp. If it doesn't come down any further I'll go back to the 192F next weekend.
    Also found my gas convertor has a leaking gasket on the bottom cover, another job to fix, at least now I have an explaination for the average LPG consumption and slight miss at idle when on LPG.
    Feb 2009
    longford, victoria
    you gotta run the heater flat out too, with the bleeder open. pretty sure its the heater... or air con, im sure some here can tell you,
    my geminis
    vp executive wagon
    Oct 2009
    A.C.T.
    replace the radiator cap too that is like your thrmostat it is overlooked in heating issues
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    Quote Originally Posted by nemesis_adrasteia View Post
    yes you must have the heater on whilst bleeding the cooling system, to get the air out of the heater core.
    Nobody wants to play with me
    VN 5ltr Calais
    Oct 2007
    Yeah I did all that, it's better but not right. My mechanic reckons the leaking convertor will also be causing cooling issues. I have the car booked in for Friday for the convertor gaskets anyway so I'll suss the cooling system out then.
  1. Air in cooling system
    By quombone in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-05-2009, 05:45 PM
  2. My Cooling System... Help
    By Explosions Hurt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-04-2008, 09:03 PM
  3. cooling system??
    By quiksilver1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-04-2006, 01:03 PM
  4. help with cooling system
    By Friction in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-04-2006, 07:50 PM
  5. Oil in the cooling system?
    By portercg in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-12-2004, 11:43 PM
