Results 1 to 8 of 8
Thread: LSD DIFF question
    2009 VE SS UTE
    Jun 2009
    Emerald
    Default LSD DIFF question
    i have a vy spac and doing burnout only one wheel spins
    why is that so?
    what would i need to do to get both spinning at the same time?
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    You need an LSD. Thats usually a good starting point. And then you need power to spin the wheels.
    And I'm going to assume that burnout was on a private road/track or skidpad...
    PS, VY S-Pac doesn't come factory with an LSD, it's an option.
    Look under your car, if the diff tag says something like "High Performance" you have a single pegger. If it says "LSD" then well... i think you get the idea.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Are you sure it is an LSD? If it is, it may need repairing or replacing.
    Visit my Facebook page
    2009 VE SS UTE
    Jun 2009
    Emerald
    i wouldnt know if it has an lsd or not, but i have the traction control button and stuff which im guessing doesnt mean anything in this context.
    i will have a look and find out what some numbers and stuff are on the diff
    Would butting a diff from a SS make any difference?
    Jesterarts's Avatar
    Nov 2005
    Mornington, VIC
    Pretty sure the SS came with LSD standard so yeah... it would make a difference.
    In regards to checking the diff.
    You want to look at item (1) in the diagram below:
    If it says:
    It is an LSD, if it says "High Performance" something or other, its a the factory NON LSD.
    2009 VE SS UTE
    Jun 2009
    Emerald
    I had a look under the car this morning and there was nothing saying LSD or high performance at all.
    I think I may have confussed myself with what an LSD does.
    What do LSD's do exactly?
    Holden VS Series II 1997 Ute - 5 Speed Manual
    Aug 2008
    Quote Originally Posted by s65481 View Post
    Limited Slip Differential + Google =
    Jesterarts's Avatar
    Nov 2005
    Mornington, VIC
  1. question about diff gears in a irs diff vs 5.0l
    By mr_clubby96 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-11-2008, 04:21 PM
  2. VS Diff question?
    By Spaced in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-09-2007, 12:41 PM
  3. Diff Question
    By Phantom VK in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 24-04-2007, 05:49 PM
  4. Diff question
    By NVS 90 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-01-2007, 05:06 PM
  5. diff question
    By Boonz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-09-2006, 01:38 PM
