Results 1 to 12 of 12
Thread: vn shifter in vk ive finished modding with pics
    commodore
    Aug 2009
    australia
    Default vn shifter in vk ive finished modding with pics
    just thought id put up a few pics of my vn shifter ive been modding to my vk baseplate it works perfect and i shortened it an inch whilst i was building it
    did it cause i hate early shifters wanted to upgrade but wanted a factory look
    VN Calais S2
    Sep 2009
    Melbourne West
    commodore
    Aug 2009
    australia
    yeah took an inch out of the shaft and inside pin thought it would be too tall standard..
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    hahah thats rad as...
    Top job dude
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
    commodore
    Aug 2009
    australia
    Quote Originally Posted by azkwazere View Post
    Top job dude
    aZk.
    thanks, still looks sought of factory but a bit more modern.
    VN SV3800/WK STATO
    Feb 2009
    Adelaide, SA
    commodore
    Aug 2009
    australia
    thanks for the comments its easy to do you start off with a vk shifter use the baseplate and the flat part of the shifter grind the tubular section off then grind the base section off the vr shifter and weld the vr top half to the vk bottom flat section after you fully gut the vr pole if you want it shortened you just cut the outer tube at the bottom only because it has barbs at the top to hold the knob on you also have to shorten the inner pin the same amount you also have to be careful you weld the vr post on the opposite side you from which you grinded it off the old base and the slot up top has to face fowards its a bit fiddly but not real hard..thought id chuck in a few instructions if anybody else wants to do one..
    skruba is offline holden, honda, pitbulls
    vp executive
    Jun 2009
    parkes nsw
    VH SS
    May 2009
    Toowoomba, Qld
    very neat indeed. Looks like it's meant to be there.
    Well done, I don't like the look of the aftermarket shifters either
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    '97 VS II Statesman 5.0L 5-Speed
    Feb 2006
    Radelaide
    commodore
    Aug 2009
    australia
    thanks for your comments guys..
  1. VS Modding
    By Barbwire in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-03-2010, 07:06 AM
  2. Any pics of B&M auto shifter in vy-wk cosule
    By 1340loco in forum VY Holden Commodore (2002 - 2004)
    Last Post: 02-09-2009, 01:08 AM
  3. Any pics of b&m Shifter installed to VR.
    By Merlin in forum V6 Development And Modification
    Last Post: 08-03-2009, 08:28 PM
  4. shifter pics
    By statement in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-01-2007, 03:00 PM
  5. what modding needs to be done to this
    By Trewman in forum General
    Last Post: 01-12-2004, 10:33 AM
