Results 1 to 7 of 7
Thread: gas conversion vx 2002 acclaim wagon 3.8l
    vx 2002
    Nov 2009
    Question gas conversion vx 2002 acclaim wagon 3.8l
    Hi
    Can anyone tell me please if my VX series 2 3.8l engine (I think it comes with cast iron heads??) can run on a LPG system (vapour type) without having valve seat recession problems down the track?
    Thanks
    Paul
    Blown V6 Hatch's Avatar
    Blown V6 Hatch is offline Too many projects.....
    VN Calais 5.0, UC Torana hatch 383, WB Ute 5.0
    Jun 2005
    Cowes, Phillip Island
    There is a very good chance you will end up with valve seat recession at some stage. Holden V6's don't like gas....Ironically, i've just finished replacing an engine in a VY due to valve seat recession.
    vx 2002
    Nov 2009
    vx 2002
    Nov 2009
    why does Valve seat recession happen when you run gas on the engine?
    cheers
    paul
    Jun 2005
    bit over 200,000 k's. While that's not low K's, it's far from high K's on a Holden V6. I've seen Ecotecs go well over 300,000 k's on petrol. This car actually had a "valve seat saver" kit installed, so don't fall for that one either.
    Valve seat recession happens because gas runs so hot and dry. Valve seats require lubrication, which comes from the petrol, when on gas however, there is no lubrication. End result is, the valves don't seat anymore.
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    Valve seat recession happens because gas runs so hot and dry. Valve seats require lubrication, which comes from the petrol, when on gas however, there is no lubrication. End result is, the valves don't seat anymore.[/QUOTE]
    Where does the lube come from when running on unleaded petrol ???
  7. Default
    the petrol provides a cooling effect on the valves when injected, but on gas the valves end up overheating and as said don't seat any more.
    having said that, when you're saving $2000 a year you're still better off with gas even if the engine doesn't last as long. by the time you need a new engine you'll have saved $20,000. don't think engines cost that much . anyway just look at taxis - 1 million kms on gas and the engines still run
    Quote Originally Posted by zai View Post
    I am not sutpid
  1. Anarklov3r's 2002 VXII Acclaim
    By anarklov3r in forum VT - VX - VU - WH - V2
    Last Post: 08-09-2009, 11:27 PM
  2. [NSW] 2002 VXII Acclaim
    By Tony. in forum Vehicles For Sale
    Last Post: 25-05-2009, 10:44 PM
  3. 2002 VY Acclaim Wagon
    By VY ACCLAIM WAGZ in forum VY - VZ - WK - WL - V2
    Last Post: 23-11-2008, 01:35 PM
  4. 2002 VX S2 Acclaim OR 2002 VX S2 SSpack
    By ruso in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-05-2006, 10:53 PM
  5. Black 2002 VY Acclaim Wagon
    By VYWagon in forum VY Holden Commodore (2002 - 2004)
    Last Post: 07-05-2005, 10:35 PM
