Results 1 to 8 of 8
Thread: question on strait gas
    WK statesman 5.7, VS exec TURBO
    Sep 2005
    mornigton penisula VIC
    Default question on strait gas
    hey guys, im lookin into building a strait gas VL turbo wagon. and im looking to make at least 250 rwkw minimum.
    so i will need to run twin gas lines right?
    can u run twin lines off any tank?
    thanks
    Sep 2005
    also. what are a good brand converter and mixers for tuning? ive heared gas reaserch isnt as easy to tune as impco or others. but i have never owned a gas car b4 so ive really got no idea
    the lightning
    Jun 2005
    under the Southern Cross
    you'll most likely need 2 converters to throw enough fuel at it to get 250 rwkw, maybe ring someone at swift automotive on dandy frankston rd, they do some tough gas cars, they push the gas research product pretty hard.
    Quote Originally Posted by one_and_only2004 View Post
    Sounds like you and your friend have a collective intelligence rivalling that of a door knob. Looks like the useless crap you fit to your car is the driver.
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    GRA is the go single 350 carby and twin GRA b2 converters no need for twin gas service lines a APA or C&J tank will supply enough gas thru a 8mm or 5/16 service twin gas lockoffs or a single highflow unit apply boost pressure to the converters and all the gas you need is there .
    Sep 2005
    so whats the go with back fires?
    do they happen on boosted cars? is there anything u can do to avoid damage to ur cooler or anything if it does happen?
    strgas's Avatar
    Oct 2009
    back fires will and can occur in any engine combo to protect your cooler you could have a spring loaded relief valve in your piping to release the back pressure
    Sep 2005
    so is that a normal thing that gas shops, or the people doing the pipeing do? or do i need to make up something my self
    strgas's Avatar
    Oct 2009
    something you may have to do yourself . there are back fire valves for lpg but they wont hold back the boost pressure . a simple spring loaded plate adjusted over the boost pressure should be enough to protect the cooler by venting the back fire pressure
  1. change cat converters to strait pipes
    By eroled in forum VY Holden Commodore (2002 - 2004)
    Last Post: 19-03-2009, 11:08 AM
  2. Quadrajet mod to run strait gas
    By ported in forum V8 Development and Modification
    Last Post: 05-05-2007, 10:44 PM
  3. Ebay question.... moral question?? lol
    By NORTI in forum The Pub
    Last Post: 03-04-2007, 03:43 PM
  4. efi vk 6 question
    By SUSPECT in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 20-10-2005, 03:27 PM
