I 've decided to install a stage two shift kit in a Vy commodore.It already has a PWR trans cooler, 3.91 gear ratio and new LSD center. Should I insist the shift kit be of the bmb brand and larger bands will be installed throughout the trans. I hope should be able to cope with extra torque. I heard you can install on your diff a mini spool locker and i've got the cash for the other upgrades to the trans but how much would the mini spool locker be aprox amount?
Mobstaopm
upgrading the trans is a good idea. The standard trans's seem to die in the ass around 130,000kms if you drive them with a little spirit.
Iv had by trans rebuilt with wider kevlar bands + clutches, beast sun shell, larger boost valve, billet steel servo's and better solenoids. I was told it would handle 650hp. Not sure if thats true or not, but iv never had a problem with it and i give it hell
