Page 1 of 3 123 LastLast
Results 1 to 25 of 71
Thread: Euro-brisk-multispark-spark-plug
    I have 2 cars VZ sv8 6 litre and VU ute 5.7 litre
    Sep 2008
    Arrow Euro-brisk-multispark-spark-plug
    I put these new plugs in last night and found a noticeable difference in the way my car runs, thought I would pass it on for anyone interested. see link below
    EURO BRISK MULTISPARK SPARK PLUG [ HOLDEN COMMODORE ] - eBay Spark Plugs, Ignition, Charging, Car Parts, Accessories, Cars, Bikes, Boats. (end time 22-Jan-10 20:34:55 AEDST)
    Spark Plug Comparison Spark Plug Research
    News letter http://www.brisksparkplugs.com.au/ne...011007%201.pdf
    Question:
    Why are Silver spark plugs "the best spark plugs in the world"?
    Answer:
    A spark plug has only one function. Deliver a spark to the combustion chamber to initiate combustion. A stronger spark means improved combustion. If the metal used for the center electrode is a poor electrical conductor, such as platinum or nickel-alloy, some of the energy is lost and the spark is weaker. A weaker spark could mean lost performance. Silver is by far the best electrical and thermal conductor of any metal. Using a large silver diameter center electrode, can mean up to 137% more spark power and therefore increased engine performance. Nology Silver spark plugs out-perform all other spark plugs and deliver the most powerful spark. That's why Silver spark plugs are the best spark plugs in the world.
    Question:
    Aren't Platinum or Iridium spark plugs the best?
    Answer:
    No. As a matter of fact, Platinum and Iridium are some of the worst metal conductors. The reason why Platinum and Iridium spark plugs are used is for longevity only. They can last up to 100,000 miles. If you are looking for longevity, they are for you. If you are looking for performance, choose silver.
    Question:
    Isn't copper a good conductor?
    Answer:
    Yes, but not the best. Silver is the best. Also, the electrodes of spark plugs with so called "copper electrodes" are not solid copper, they are copper core. This means, an electrode made out of a poor conducting material, usually nickel-alloy, with a copper core. This only benefits heat dissipation, not performance.
    Question:
    Doesn't a silver electrode melt?
    Answer:
    No. Just like conventional spark plugs, Silver spark plugs are available in different heat ranges. If the correct heatrange is chosen, thermal problems won't arise.
    Question:
    Why is heatrange so important?
    Answer:
    If a spark plug doesn't have the correct heat range for the engine, engine failure can occur. A spark plug that is too cold won't reach optimum operating temperature and could experience carbon build-up or oil-fouling. A spark plug that is too hot can overheat and melt the electrode.
    Question:
    Won't a "hotter" spark plug make a hotter spark?
    Answer:
    No. A hotter, or colder spark plug refers only to the ability of the spark plug to dissipate heat. A colder spark plug dissipates heat faster than a hotter spark plug.
    Question:
    Do I need to change spark plug heat range when I use Silver?
    Answer:
    No. Spark plug heatrange stays the same.
    Question:
    I noticed that Silver spark plugs are only available in a few heatranges?
    Answer:
    Yes, that's correct. Silver is also the best thermal conductor of any metal. In managing the ever changing combustion chamber temperatures, caused by different engine and load conditions, silver is unsurpassed. To prevent plug fouling, optimum operating temperature is reached shortly after start up, yet under full throttle, when things really start to get hot, heat is dissipated rapidly. Silver spark plugs provide the widest heatrange latitude and therefore cover all heatranges with fewer models.
    Question:
    The Silver spark plugs recommended for my engine look like they are a much hotter heatrange than the spark plugs I normally use?
    Answer:
    Because the thermal conductivity of silver is so much better than that of any other metal, the physical appearance of Silver spark plugs will be different.
    Question:
    Isn't a split electrode or a fine wire electrode better?
    Answer:
    It depends on the application. Since the ionization voltage of spark plugs with split electrodes or fine wire electrodes is lower, they are perfect for older vehicles with weak ignition systems. But since spark voltage is lower, they are not desired for performance applications. In addition, electrical energy travels on the outside of a conductor and not through the middle as commonly assumed, and since a large diameter center electrode offers a larger surface area, spark carrying ability is increased when the center electrode has a large diameter. To put it simply, you can't fit a big spark through a tiny electrode.
    Question:
    Is there a noticeable improvement if I use Silver, and if yes, why?
    Answer:
    Yes. The combination of using silver and having a large diameter center electrode increases Silver's spark carrying ability and spark power.
    Question:
    Are there any other reasons why Silver spark plugs are superior?
    Answer:
    Yes. Silver spark plugs are manufactured to highest quality standards and are made exclusively out of top grade materials. The extra pure aluminum oxide insulator is of the purest material available. This gives Silver spark plugs the highest reliability together with very good high voltage insulation.
    Question:
    How long will Silver spark plugs last?
    Answer:
    The spark plugs will last up to three times as long as conventional spark plugs. Silver is a precious metal and therefore extremely resistant to erosion, guaranteeing a virtually unchanged electrode gap for the life of the spark plug.
    Question:
    What about spark plug gap?
    Answer:
    The spark plug gap is the same as the one recommended by the manufacturer of the engine in which the spark plugs are to be used.
    Back To Top
    Question:
    What's the best way to gap spark plugs?
    Answer:
    To gap spark plugs always use a spark plug gapping tool. Never pry the ground electrode with a screwdriver or similar object. This could permanently damage the ceramic insulator and the center electrode, making the spark plug inoperable and voiding the warranty.
    Question:
    Why do I need resistor plugs?
    Answer:
    You don't always need to use resistor spark plugs. True, some electronic engine management systems are very sensitive to RFI or EMI and if non-resistor spark plugs are used the engine doesn't work properly. However, most engines will not experience any problems with non-resistor spark plugs, especially if there is some resistance in the spark plug cap or the wires.
    Question:
    So non-resistor spark plugs are better for performance?
    Answer:
    Yes. If you are looking for performance you want to use non-resistor spark plugs. A resistor is exactly what the word implies. When the spark crosses the point of resistance some of the spark energy is lost. A resistor is like an electronic obstacle and could be the cause for a weak spark. Non-resistor spark plugs deliver a more powerful spark.
    Question:
    Why do car manufacturers recommend resistor spark plugs?
    Answer:
    One reasons is actually emissions. Since the resistor is an obstacle it forces the spark voltage to be higher, assuring combustion in a lean mixture. Also resistor plugs are MUCH cheaper to produce. You will never find resistor plugs in serious race cars, yet these cars use some of the most sophisticated engine management and data acquisition systems. But these cars have no EMI problems. Why? The spark happens inside the combustion chamber where he is completely shielded by the metal cylinder head. No EMI can escape the combustion chamber.
    Question:
    How tight should spark plugs be?
    Answer:
    This is a very important point. Most of the time spark plugs are too tight, (over torqued). This will result in a deformed spark plug, with the internal seal damaged. A spark plug damaged this way can lead to premature spark plug failure and even engine damage. For proper torque values, please check with the spark plug manufacturer.
    Back To Top
    Question:
    I read something about antiseize and silicone grease. What are they for?
    Answer:
    Before installing any spark plug always apply antiseize to threads. This assures easy removal of the spark plug and prevents corrosion and seizing. For best high voltage insulation, to prevent arcing-over on the outside of the aluminum oxide insulator and to repel moisture, always apply a high quality silicone grease to the inside of the spark plug boot.
    I'm not trying to sell the product nor trying to proves its any better than anyone else's plug, but at the same time its good to know what's out there and what's available, then people can make the choice.
    I have found heaps of information on this forum, some I like some I don't, but at the same time its all good. especially for those that don't have mechanical aptitude and want to know more of what's out there.
    Last year I replaced the plugs both in my VZ and VU with a set of iridium plugs purchased from Bursons and recommended by them, to tell you the truth I wasn't really happy with the way the cars ran. So when I took some leave at Christmas I did some homework, to cut a long story very short I purchased a set of genuine Holden iridium's for the VZ and a set of Brisks for the VU. Both cars now run like they should and yes Bursons probably sold my the wrong set of plugs but I used this forum and did home work and I'm now a happy man, so why not pass that all on, because at the end of the day its all for free !
    VS L67 Statesman
    Oct 2006
    Melbourne, VIC
    Sep 2008
    Quote Originally Posted by Thomas1 View Post
    I run Brisk LGS series plugs in my L67 and love them
    Tell me about it, i was unsure at first but thought what the heck give them a try I was very impressed I must say
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    I actually read the ebay ad from top to bottom getting more and more impressed, until I came across the part where try try to claim silver is a better conductor of electricity than gold, at that point I closed the window.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    VS Berlina 3.8
    Dec 2008
    VS L67 Statesman
    Oct 2006
    Melbourne, VIC
    Quote Originally Posted by _R_J_K_ View Post
    Yeah, not for $24 PER plug.
    There is a group buy for them at the moment on www.l67torque.com • Index page
    Sep 2008
    Quote Originally Posted by Vee-ard View Post
    All metals can conduct electricity. The best conductor is silver.
    Then Copper
    Here is a list of specific resistance in Ohms*mm^2/m
    - Silver - 0.016
    - Copper - 0.0175
    - Gold - 0.022
    - Aluminum 0.0278
    Those are the best conductors according their rank.
    What about Iridium Spark Plugs?
    Iridium is a super dense material and therefore extremely resistant to wear. That's it!
    It is a terrible thermal conductor and a bad electrical conductor, so why would anyone use it to make a spark plug center electrode? Since car manufacturers have to guaranty that their engines stay in-tune for up to 100,000 miles, they can only achieve this with ultra dense Iridium or Platinum.
    Silver spark plugs are especially designed for high-performance engines. Silver is the best electrical and thermal conductor of any metal, which makes it the ultimate material for a spark plug's center electrode. The large diameter silver center electrode increases spark carrying ability and spark power. Silver is extremely resistant to erosion, guaranteeing a virtually unchanged electrode gap for the life of the spark plug.Silver spark plugs are without a resistor, perfect for performance enthusiasts who demand the most from their engines. For racing or dependability and efficiency for everyday use, Silver spark plugs deliver the most powerful spark.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Silver is actually the best conductor but it is more prone to surface corrosion than gold or platinum.
    Visit my Facebook page
    VT 2
    Nov 2008
    Couple of points -
    The 'Skin effect' they are talking about - where the signal passes around the surface of the conductor, has no bearing on spark plug performace. RF signals being extremely low current are most affected by the skin effect. Some very high quality cables for radio and tv signal are actually hollow tube conductors.
    Think of it this way - signals are electrons moving through molecular structures. Push an electron into the orbit of a molecule and an electron will pop out the far side. A bit like a hose full of marbles. Push a marble in one end and one will pop out the other. The conductor is made up of a 3 dimensional lattice of molecules. Push an electron in to the lattice and one pops out the other end. In between though, the electron may pop sideways a few million times. The electron doesn't follow the shortest course, it's quite randomn. At the 'skin' of the conductor though, there are fewer joins to other molecules. It limits the directions in which the extra electron can move. So the signal spreads faster at the skin.
    However - you need more than just a one molecule thick 'skin' to carry large currents. And the Current transmitted is very important. Mathematically V = IR, where V= Volatge, I = current and R = resistance. If the resistance is very low, you need a much higher current to produce the same voltage. A 10 amp circuit needs 1.0 sqmm cross section copper cable to carry it, at 12 volts. 15 amps 1.5sqmm. 20 amp 2.0 and so on. These are the ADR ratings for the copper cables. It's also why the better cables are made of finer strands. More skin effect plus more total copper in cropss section, = best of both worlds. This is especially obvious in Top End Audio cables, and in comparison, Battery cables. Audio = hundreds of ultra fine strands (315 x 0.08 mm diameter strands is not uncommon for SERIOUS audio, but only totals 1.5mm cross section. the common 15 amp cable for car power is 30 strands x 0.25 mm diameter. Same cross section, just no need for the skin effect). 100 Amp Battery cables (3AWG) are usually 196 strands x 0.4 mm diameter, as current is more important here.
    Why do they use stranded cables then and not big lumps of copper ? Flexibility and resistance to vibration. Flexibility is obvious, but copper will tend to fracture at bends if subjected to continuous vibration, so they anneal the copper by basically rubbing the outer surface alot, softening it and increasing vibration resistance. Since annealing doesn't penetrate very deeply into the copper, they use small strands, just lots of them.
    Solid copper cables should only be used in situations where no movement or vibration occurs - like in the walls of a house or building, or buried in concrete - or where the skin effect is not required.
    Sep 2008
    Quote Originally Posted by Tsunamix View Post
    Couple of points -
    Sounds good, but what does 20 amp fuses 196 strands of wire and 100 amp battery cables got to do with spark plugs
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    It has a lot to do with conductivity.
    Sep 2008
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Then Copper
    - Silver - 0.016
    - Copper - 0.0175
    - Gold - 0.022
    - Aluminum 0.0278
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    lmao, this has all the makings of those "halo" spark plugs which failed miserably as well.
    good luck with your 24 dollar spark plugs boys! and when you can explain why the spark would jump over more than one point when electricity always follows the route of least resistance then i may be silly and waste my money on them too.
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Maaan you're better off saving your money and buying good spark leads. You'll get better "resistance" bang for your buck that way. Got more money to throw around? Get a good coil and a good dizzy. Then buy cheap spark plugs and change them every time you drop your oil
    The 1972 HQ Kingswood
  15. #15
    ari666's Avatar
    1966 impala
    Mar 2009
    i have been thinking about this in more depth, and i really would like people to be informed about junk like this so they dont waste their money.
    silver is great. really good conductor. but the problem is that when its put under high temps high pressure situations it oxodises really quickly, oxodisation=no more conductivity. the reason they use iridium is it has a massivly high melting point and the tip will be iridium for the next 100,000kms, not iridiumoxide. the reason they cost so much is... well iridium is friggin expensive. they have to pay and arm a bunch of african militia to get it at the current prices so there is blood on it too, but thats a story for another day.
    and the tips of these things are just a joke. having 4 anodes does not give you multiple spark. all it does it randomise which anode the spark is going to jump from, it will always be the one with least resistance, untill that anode wears out then it will move to the next closest one.
    the only way to get multiple spark is to modify your ignition system. done. thats it. those split fire spark plugs are the same gimmick and completely useless.
    there is absolutely nothing wrong with copper plugs. your car was built and designed with them in mind. iridiums and platinums are only better cos' they LAST longer. the reason your car may be running better with these plugs is cos you just changed the spark plugs...
    if you were running spastic boost, or over the top compression ratio i would suggest you look at upgrading plugs, but if your running stock internals, then dont even look twice at junk like this.
    sorry OP.
  16. #16
    ari666's Avatar
    1966 impala
    Mar 2009
    Quote Originally Posted by black as View Post
    question:
    Answer:
    ahahahahahahah
  17. #17
    Sep 2008
    Quote Originally Posted by ari666 View Post
    if you were running spastic boost, or over the top compression ratio i would suggest you look at upgrading plugs, but if your running stock internals, then don't even look twice at junk like this.
    sorry OP.
    As I said in my initial statement "I put these new plugs in last night and found a noticeable difference in the way my car runs, thought I would pass it on for anyone interested" a week later I'm still impressed.
  18. #18
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Take them out and put new standard plugs in and I bet you couldn't tell the difference.
    I'm with ari, good sales pitch aimed at the gullible.
  19. #19
    Jun 2005
    he already explained why that is above. that and its probably got a placebo effect going on in your mind to justify buying them in the first place
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
  20. #20
    Sep 2008
    It's is better to be silent and thought a fool than to open your mouth and prove it
  21. #21
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Why are you still speaking then?
  22. #22
    ari666's Avatar
    1966 impala
    Mar 2009
    Quote Originally Posted by stocky View Post
    +1 to that! would wanna be a hell-good placebo effect to justify 192 smackaroonies on spark plugs.
    lets not turn this into a sh1tfight though. i wasnt having a go at you OP and spark plugs is very much a 'horses for courses' subject, i just wanted to warn people that there is a lot more to spark plug selection than just "ooh, its made of silver so must be good"
  23. #23
    Sep 2008
    I sure am
    About 50 million years ago an asteroid crashed into Earth and
    wiped out the dinosaurs. What was left behind is a layer
    of Iridium-rich clay all over the world.
    They should have left the Iridium buried!
  24. #24
    Sep 2008
    valid point ari666 but its good to know whats out there and each person can make a choice rather than being so f#&CK@#% OBJECTIVE. I couldn't give a F---- if you bought them or if you didn't to tell you the truth
  25. #25
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    I know snake oil when I see it, but as this thread proves once again, a fool and his money are soon parted.
    The "seat of the pants" dyno is zero indication of the effectiveness of this kind of product because the potential for placebo is much greater than the potential real-life benefit.
    OP, if you're really willing to stand behind your claims, buy 3 sets of plugs - one copper, one iridium, and one your magic silver plugs, then get your mechanic to randomly install one set (without telling you which). Do this for 10 weeks, recording which set your think you have in your car each week, and get your mechanic to record which actually goes in, then at the end compare. If you get even 50% right I'd be surprised.
    DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
    Quote Originally Posted by Reaper
    I think Joe Hockey is one of their best performers and I hope he gets [around] quickly - for everybody's benefit.
  1. Spark lead to spark plug order...
    By james_and_his_vp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-04-2007, 08:33 PM
  2. Spark Plug Gap???
    By markc3012 in forum V8 Development and Modification
    Last Post: 26-10-2005, 06:15 PM
  3. Spark Plug Help
    By sk00bs in forum VL Holden Commodore (1986 - 1988)
    Last Post: 26-10-2005, 03:56 AM
  4. Spark Plug Leads Getting 'baked' on to Spark Plugs?
    By holden#1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-09-2005, 04:16 PM
  5. Spark plug gap???
    By TheLucksta in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-06-2004, 04:14 PM
