Results 1 to 5 of 5
Thread: efi fuel pump
    v8commy is offline Banned
    vk calais 5.0
    Mar 2009
    reynella sa
    Default efi fuel pump
    can anyone tell me what the pump pressure of a standard vn v8 pump is? and can i run 2 standard vl 3l pumps instead of a single pump or just one vl pump? will i need a higher pressure pump if i run higher pressure injectors
    vk calais 5.0
    Mar 2009
    reynella sa
    VXII
    Nov 2009
    Not enough info supplied.
    The pressure of a fuel pump is determined by the fuel pressure regulator, not the pump itself. Maximum pressure of a pump will vary due to voltage fluctuations and flow rate among other factors.
    Putting two pumps in either series or parallel won't boost pressures any higher than one pump will.
    Why not buy a fuel pressure regulator to match the injectors?
    vq 5.0l
    Sep 2009
    howdy,
    Have had a bit of fun with these.
    Standard VN uses two pumps 1 low pressure or lift pump in the tank and a seperate high pressure pump externally.
    pressure straight out of the pumps into the gauge (dead ended) will be around 600 kpa
    pressure at the fuel rail will be around 320kpa normally.
    VPs and utes have a single high pressure pump in the tank,
    as a hint if you need to replace pumps you can replace the low pressure in tank pump with a high pressure one (bit of mods needed they are longer) and delete the external pump. this is the cheaper option as internals are about $100 and externals around $220
    I reckon V6 high pressure internal pumps are the same, I have run one of these with no exteral pump on my 5L with no probs
    Hope this helps
    Hoots
    vk calais 5.0
    Mar 2009
    reynella sa
    Quote Originally Posted by hoots View Post
    howdy,
    Hope this helps
    Hoots
    thanks mate exactly what i needed to know
  1. cracking open fuel tank to change fuel pump?!
    By VS5spdV6uteowner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2009, 08:00 AM
  2. Will a fuel pump pump oil?
    By VYMAD in forum General
    Last Post: 12-11-2008, 09:07 AM
  3. Fuel pump issue, or fuel line blockage? not sure help!
    By SKNOT9 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-09-2008, 02:08 PM
  4. leaking fuel damper and fuel pump adventures
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-08-2006, 04:00 PM
  5. VS Internal fuel pump issue (duel fuel)!!!
    By futronix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-09-2005, 08:10 PM
