can a v6 ecu and memcal be converted to a v8 and what wiring loomb would you run with it?
bump................
vn-vr.......
Yes i believe they can be. not sure about the wires or loom.
ok i need someone like greenfoam or delcowizzard to reply as they are experienced in this
vn-vp ecus are same regardless of motor designation.
memcals are different, but can be changed between the 2 with some resistors fro memory.
vr manual ecus are the same v6-v8. memcals different
vr autos i cant remember.
you use what ever wiring loom the motor needs. v8 loom for v8, v6 for v6, since all the sensors are in different spots.
