Results 1 to 9 of 9
Thread: wheel bearing?? how do i know??
    IDO-360 is offline 3800cc
    vp spak
    Dec 2009
    Question wheel bearing?? how do i know??
    my vp commodore is makinga funny winding sound on the left side of my car wen i put my foot dwn. . sounds like its cuming from te wheel is it a wheel bearing??
    Shaundy's Avatar
    Shaundy is offline BMW Technician Apprentice
    VS Executive S2 BT1
    Jan 2009
    If its a wheel bearing I'm led to believe that the noise should get louder when cornering....
    This VS is guarded by shotgun 4 nights per week - You guess which 4!
    My BT1:
    [SIGPIC][/SIGPIC]
    VX S S2
    Dec 2007
    Laidley, QLD
    it will also sound louder the quicker the car is moving and then lower as the car is slowing down, well mine did this when it was about to die.
    VS HSV Clubsport
    Jan 2009
    Wellington, NZ
    v8commie is offline Banned
    vk calais 5.0 efi
    Feb 2010
    for the front pull and push the wheel in a in and out motion if there is play would indicate bearing play which would result in noise for the rear youve really gotta take out the axle and have a look
    vr executive wagon
    Mar 2010
    can u tell if its coming from front or rear. It could be a wheel bearing, diff or uni joints in your tail shaft you said when u put your foot down (only when ) or it gets louder???
    VH SL/E, R33 GTST
    Mar 2010
    Berwick
    is the noise a "whine" or clicking/crunching noise? my wheel bearings on my vk had to be changed, and they were crunching and clicking, the slower the car wen the slower the noise happened, when driving in a straight line, do you feel the car jerk sideways? as if the wheel is slightly loose? can you keep your steering wheel dead straight and not have the car pull eather side and have to correct it? (the jerk is only very minute) if it does this, replace your bearings.
    2004 XR6T & 1990 VN dragcar project
    Jan 2010
    Bendigo, Victoria
    Easiest way to check if you've done a wheel bearing: When it finally goes, your wheel will fall off doing 110kp/h on the hume.
    Well thats what happened to a bloke I know, lol.
    vr series 2 v6
    Oct 2009
    nsw
    easy way i got taught, when checking tyre rod ends, grab ure front tyre by the each side horizontally (not top and bottom) and see if there is movement, if there is thats your tyre rod end if not its not, and with wheel bearing grab the tyre from top and bottom (when jacked) and see if there is movement vertically and if there is thats your wheel bearing (sorry about poor spelling)
    Vs eco 3.8, extractors, 2.75" exhaust, roller rockers, cammed, bored out 20, t5 manual, rolling on king springs all way round with monroe gt shocks all way round, every door has a ding but looks can be very deceaving
  1. Wheel bearing?
    By Slippy_Trippy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-06-2009, 06:39 PM
  2. Thrown a wheel bearing?
    By synoptica in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 14-01-2006, 06:25 PM
  3. wheel bearing access???
    By VN-88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-10-2005, 12:44 PM
  4. Wheel Bearing or Brake
    By Stretcher Bearer in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-10-2005, 09:00 AM
  5. wheel bearing gone?
    By walace in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-10-2005, 11:42 PM
