Results 1 to 5 of 5
Thread: Anyone used a Refractometer for Engine Coolant Glycol Levels?
    VY S V6 Ute Series II 2004
    Nov 2009
    Default Anyone used a Refractometer for Engine Coolant Glycol Levels?
    I recently drained and flushed the engine coolant in my ute the other day. Its a 50/50 mix of water and ethylene glycol based corrosion inhibiter/antifreeze required for my VY.
    I mixed it up to the correct ratio and bunged it in.
    A few days later I borrowed a a refractometer for measuring the % of inhibiter/antifreeze in the coolant from a mate. (He found it on e-bay new from China for about $50).
    I've never seen one before. Seems like a well made instrument, with three scales through the viewfinder for Ethylene Glycol, Propyline Glycol (gives you the %) and also battery fluid (good/fair/recharge).
    You put a drop of the coolant on the glass prism, close the lid and hold it up to the light and read the refractive index of the liquid on the scale.
    I tested the fluid I thought was 50% and the refractometer tells me it's 62%
    Has anybody used one of these before? Are they accurate?
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    TVR-190's Avatar
    TVR-190 is offline SkyFall
    WK Statesman LS1
    Jun 2008
    Sutherland Shire N.S.W
    ari666's Avatar
    1966 impala
    Mar 2009
    AHA HAHAHA... (some lower case letters for the caps monster)
    dude! i cant believe you were actually driving you car with that ratio!!! good thing you checked.
    Nov 2009
    I've tested the levels in a couple of brand new cars (Subaru) and they give a reading of exactly 50%. (to spec)
    I think they would spot on straight from the factory.
  1. Coolant coming out through engine
    By 89 vn in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-07-2009, 04:22 PM
  2. Engine coolant
    By coder in forum General
    Last Post: 04-06-2009, 11:36 AM
  3. VT V6 - Coolant in engine oil?
    By vtbob in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-05-2009, 06:34 AM
  4. Coolant from engine :|
    By mking in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-02-2008, 12:00 PM
  5. WHAT COOLANT IS BEST FOR MY ENGINE? help!
    By r_i_d_a_h in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-12-2006, 02:13 PM
