Results 1 to 13 of 13
Thread: good suspension and brake specialists
    vt equipe wagon
    Feb 2010
    Default good suspension and brake specialists
    hey got a quote from pedders $2300
    who else is good in sydney, near camperdown, inner west
    who is good to get brakes done by too?
    vt equipe wagon
    Feb 2010
    VS Berlina 3.8
    Dec 2008
    Would kinda help if you told us what you were getting a quote for and what you want done.
    Other than that, check out GSL Rally Sport in the site sponsor section.
    As for places near you - http://www.yellowpages.com.au/
    vt equipe wagon
    Feb 2010
    this is the quote from pedders
    new front shocks 560
    sway bar bushes, have worn links 190
    worn upper mounts on upper bushes 170
    lower bushes-movement in tower bushes 560
    radius bushes 390
    bumpstops- boots broken, bumpstops worn 90
    rear shocks 300
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    Quote Originally Posted by dubguy View Post
    Probably the fairest quote of the bunch.
    Rip-off. Aftermarket heavy duty links can be had for under $50, it'll take them 10 minutes of labour once the struts are already off.
    No idea on that one.
    They are doing the struts, so there should be no extra labour charge here. The parts themselves should only be about $200, so that's a total rip job.
    radius bushes 390
    Bushes are about $150 for the pair, pretty sure it won't take them 3hrs to fit them...
    As with the strut tower bushes, no additional labour involved. That's a spastic price for bump stops and boots. Also, it's interesting they can tell that without taking the struts off the car...
    rear shocks 300
    Shocks should be about $70 each, takes them all of 15 minutes to fit them. $200 would be closer to the mark.
    DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
    Quote Originally Posted by Reaper
    I think Joe Hockey is one of their best performers and I hope he gets [around] quickly - for everybody's benefit.
    vt equipe wagon
    Feb 2010
    ok, SO WHERE CAN ANY ONE RECOMEND????? are we not allowed recomend places on here or what? there must be someone on here, that has used some one time and time again, that is good, come on lads
    vt equipe wagon
    Feb 2010
    danja's Avatar
    Jan 2006
    If you want a good job, try Heasman's Steering in Tempe. They aren't the cheapest, but they are very good at what they do.
    vt equipe wagon
    Feb 2010
    vt equipe wagon
    Feb 2010
    vt equipe wagon
    Feb 2010
    well tanks danja, went to heasmans this morning. they checked it and unlike pedders, who said everything needed replacing, they said everything is fine, drive it another while and bring in if the noise gets worse, and it might be easier to pin point. shocks ok, sway bar links ok,just a few bushes at some stage, but nothing major.
    he said if i really wanted to replace the worn bushes, it would be $110 dollars, but he wouldnt bother yet.
    some difference from pedders who quoted $2300.
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Yeah Pedders do that.
    Ronald Reagan (1986)
    vz crewman
    Apr 2010
    front shocks -Are available through Monroe for about $100.00 each, and also available genuine for about the same.
    sway bar bushes have worn links. -Link pin kits are available aftermarket for around $50.00 a pair.
    worn upper mounts on upper bushes. Strut top bushes tend to sag and then knock over bumps. they are available new for around $30.00 each
    lower bushes-movement in tower bushes. Same as above (strut top bushes).
    radius bushes. -Cost about $165.00 each genune however Id go with the Super Pro brand which are around $160 a pair.
    bumpstops- Strut bellows are prone to falling apart, you can either leave them out or go for aftermarket for around $50.00 a pair.
    rear shocks- You can buy a pair of Monroe shocks for around $140.00 a pair.
    Id stick with the super pro brand on you caster and sway bar links however I'd use genuine strut top bushes, whilst you're changing your strut top bushes I'd also change the strut top swivel bearings that sell for around $28.00 each.
    I'm sure that Monroe Australia produce the Pedders range of shock absorbers and I'm also pretty sure that the Pedders brand have a slightly different and heavier valve body installed in them. Your labor costs to have both front struts and caster bushes removed, replaced, dismantled and assembled should be around the $250.00 mark and then you'll be up for around $50.00 for a front wheel alignment. To have your rear shockers fitted the labor should be around the $80.00 mark. If you go to reputable mechanical workshop his hourly rate will be between $50.00 and $90.00 per hour, and if you choose to go to a dealership that can rise to anything up to $150.00 per hour.
  1. good suspension places
    By nathg in forum General
    Last Post: 08-12-2008, 10:18 PM
  2. fe2 suspension any good guys ?????????
    By muzza in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-11-2007, 09:36 PM
  3. FE2 suspension on VX good?
    By InnocentMJ in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-10-2007, 08:34 PM
  4. help,help,,all specialists of VR,,,
    By protossw in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-09-2006, 10:17 PM
  5. new suspension $910 is this a good price
    By SYM35 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-12-2005, 09:40 PM
