Results 1 to 7 of 7
Thread: volts, oil pressure,water temp gauges
    1993 yota 4 runner sr5. Sadly sold vp s
    Oct 2009
    sa
    Default volts, oil pressure,water temp gauges
    hey i was just wondering how hard is it to fit these 3 gauges can you do a diy job if so can any1 give tips or hints on what 2 do
    tr3nt's Avatar
    tr3nt is offline trent was 'ere
    VP Calais International 5L
    Sep 2003
    Melbourne, AU
    Very easy DIY - I've been told with Oil Pressure there's 'sandwich plate' you can get that sits between the oil filter and oil pump to get the reading, and the water temp can by sensored from a part that goes into a radiator hose near the radiator itself. Volts can be basically tapped in anywhere electrical, I have mine running off the ignition.
    Quote Originally Posted by hakhawk View Post
    if you pay for fuel, ill drive up and drive you around in the bmw. assuming your(hopefully hot) date rides shotgun, and you get the boot, dont worry, its well ventilated if ur dates not so, you can share the boot
    Oct 2009
    sa
    ok so give me a run down on each 1
    where is the best place to do the volts 2
    can you show me some pics if possible
    vn ss 355, vl, vr, vs ss
    Jan 2010
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    no offense or anything... ahhh **** it, take offense... but if you dont know how to wire it up, why would you need a volts guage?
    In all seriousness, the only reason you need it is to monitor the voltage in your system and id hazard a guess and say you wouldnt know what to do if it did start dropping because you cant even wire it in... really basic car electronics here.
    Will the guage serve any purpose other than just "looking sweet"?
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
    SMIT's Avatar
    SMIT is offline Donating Member
    VT C2R TURBO 5SP + CRUNCH VE SSV 6SP
    Aug 2005
    Mornington Peninsula, Victoria
    Oil Pressure:
    Never use mechanical oil pressure guages unless mounted outside the car.
    1. mount guage. get +ve and -ve and illumination, easiest place would be from the cigarette lighter afaik the speco/autometer 2" guages draw around 2-3 amps and should ok on the same fuse ( i run 4 of them)
    2. Find oil pressure switch - it is located on the engine, near the bottome, just above the sump (near the pwr steering pumps, i think?) on all buick/ecotec engines, you then can either take the oil pressure switch out ir by a t-tap so you can connect both the pressure switch and and sender unit (for the guage, useally 1 wire)
    3. run a wire from the sender unit to the guage
    For the water temp you will need to buy a joiner for your top radiator hose that has a thread in it, in which you can screw the sender unit into (automter/speco make them, around $25 from repco/autobarn etc)
    well thats a preety basic explanation, they are preety easy to do, and i cant be bothered to spell check because im tired.
    Oct 2009
    sa
    Quote Originally Posted by azkwazere View Post
    aZk.
    yea thanks mate that helps heaps......... i asked a question that wasnt a stupid and obv im not the only person who would like to know. if every1 made comments like you did this site wouldnt run. i think u should take a chill pill and let the people who want to help & give advise comment. personally i dont car what you think.....................
    thanks to every1 that is giving good advice
    btw pics would be good
  1. oil pressure, oil temp and fuel/air gauges install
    By PSYKO PHOENIX in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2009, 09:59 AM
  2. gauges - water temp and oil pressure
    Last Post: 13-12-2008, 07:20 AM
  3. gauges oil temp and engine temp
    By vzon20s in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 24-11-2008, 05:31 PM
  4. Electric oil temp and water temp gauges
    By FRESH_VR in forum General
    Last Post: 02-09-2008, 04:27 PM
  5. Installing Gauges...water + Oil Temp, Oil Pressure Help Needed
    By VXGASSED in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-04-2006, 04:29 PM
