Results 1 to 13 of 13
Thread: SARD FPR in a returnless setup - do I have the right idea??
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Question SARD FPR in a returnless setup - do I have the right idea??
    Returnless setup in a VN LS1, I have a SARD 'standard' FPR - 200-800KPa:
    I reckon i might have to set fuel pressure with a gauge in the FPR, then once I get it set to 60psi, depressurise, remove gauge, replace gauge with fitting to returnless line to engine rail.
    Sound about right?
    I can scan up a quick sketch if that was stupid or confusing...
    Sam
    WTB: mulberry VN interior parts
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    is it a 2 port reg or is that suppose to be for a pressure gauge? yes it would but you would still need to run the return line from the bottom of the reg back to the tank. like this
    pump ------>---------->---------- reg ------>------>---- fuel rail
    tank --------<---------<-------------l
    Body by Holden, Soul by Brock
    the Legend will live forever
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Yeah that 2nd port is normally for fuel gauge
    Anyway a couple of guys on other forums have given me the answer
    SIMPLE
    Run a T piece after the fuel pump, anywhere in the line to the rail this T piece goes off to the FPR. Mount the gauge permanently in the FPR for troubleshooting later on if needed. And, obviously, return gets plumbed back to the tank
    win
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    hehe not that hard was it all sorted much left to go on it now
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Need to find a T piece for the piping, hoping to have fuel system done tomorrow
    do I use teflon tape or anything on the fittings to the FPR? does that stuff dissolve in fuel?
    after fuel system, not that much to go.
    Wiring up the conversion engine harness
    Test fire
    Power steering lines
    Coolant setup
    Fill fluids
    Fit tailshaft
    Install driver's seat
    Go for test drive
    Check signature link for more details
    в∞ѕтεכ √&
    Jul 2008
    NZ
    you can get liquid thread sealer but i just use teflon tape theres a few kinds all different names for use in different situations but it doesnt really matter they all seal
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Awesome, thanks.
    I'll use whatever stuff I have and keep an eye out for leaks over the first few weeks
    Apr 2006
    Auckland NZ
    it's all good, i run the non return setup in my VH. if the reg is 2port (1 in/1 out) then you need to run a T piece. if you have a 3 port reg ( 2in/1out) then you don't need the T piece as it's all done through the reg. you can put a fuel pressure gauge anywhere in the system. personally i'd mount it by the fuel rail somewhere as that is where you need to be certain it is correct. filters, well that's up to you but again as close to the fuel rail as possible. that way it eliminates any issues with crap that may be in the lines.
    i prefer liquid thread sealer but it's a bit expensive to buy for a single job. fortunately i have excess to it at work (sometimes when we haven't run out)
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Thanks, I don't want to stuff around with finding a gauge to mount up on the rail when I have one that came with the FPR.
    It is a 3 port FPR but I'd rather set it up with a T piece in the line anyway to leave that 3rd port in the reg free for permanently mounting the gauge.
    Blown V6 Hatch's Avatar
    Blown V6 Hatch is offline Too many projects.....
    VN Calais 5.0, UC Torana hatch 383, WB Ute 5.0
    Jun 2005
    Cowes, Phillip Island
    Keep teflon tape well away from fuel...Use a proper liquid sealer. I've seen teflon tape end up in carby needle & seats, injectors, gauges many times before. Worst thing you could possibly use on fuel fittings.
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    OK great, I've just been out for two hours on a bull shit run around for fittings etc, come home to find out I need to go get more shit...
    My timing is fail.
    I'll see if it leaks with no tape on it ... 1/8th NPT, tapered thread, I think they might be OK just as they are... but if not, I'll use CAREFULLY PLACED teflon tape until such a time as I get some proper liquid sealant
    в∞ѕтεכ √&
    Jul 2008
    NZ
    youll find the npt fittings without tape will leak and wont screw in properly .just dont put the tape right at the end of the thread so it doesnt get pulled off the end into the fitting and youll be sweet ive lost count at the amount of fittings ive done with it now no issues all our surge tanks are done with it and every other npt fitting all my oil feeds are done with it too due to leaks
  1. Idea for VS
    By vs2nvi in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-01-2010, 12:41 PM
  2. Good Idea? Bad Idea?
    By WogBoyz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-03-2009, 01:00 PM
  3. My new idea
    By LightningVP in forum General
    Last Post: 11-10-2008, 04:33 PM
  4. VK Stock drum and disk setup to a VT disk setup
    By justinp in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 19-02-2006, 09:37 PM
  5. bad idea ?
    By brettyb2002 in forum Electrical Wiring / Questions
    Last Post: 09-09-2005, 12:57 PM
