im looking at painting some mags to go on my new wagon, just a mat black finish is all im after
what will i need to do to the rims b4 spraying them(i have comp and spray gun)?
how many coats u reckon/ what kind of paint?
has any 1 done this before that knows what there doing as i dont want to have to do it time after time,
also i assume i cany do it with the tyres on etc etc..
thanks 4 ur help
When i was younger i owned a Datto Wagon 200B. It was light blue on white and i wanted to paint the rims the same colour as the roof (light blue).
All i did was clean them thoroughly, cover the tyres and paint the rims. they turned out great and lasted for quite a few years, the car ended up breaking before the paint wore away LOL.
Althou, if the mags are a nice mag..........i'd suggest maybe getting them professionally dipped instead of painting them yourself?
Depends on how nice they are to start with.
Follow Your Dreams......RIP Brocky 1945 - 2006......May God Rest Your Soul
yeah the wheels are in good nic, 2 have tyres 3 dont, i would love to get them done professionaly, but the finacial adviser(the missus) wont alow it, therfore on a budget and just want a diff look as the car is a boring white
im fairly sure theres a clear coat on all factory wheels, will i need to sand/strip b4 painting?
Is this some sort of 5 wheeled super beast lol
In all seriousness I would reccomend you don't paint them matte, they will look dirty all the time.
I would reccomend VHT wheel paint, as its made for wheels, heat resistant and is polyurthane based so it doesn't chip.
If you are after a neat black colour, buy a can of VHT SP183. Saturn Black. Will give you the look of matte but still have a shine.
Ben
There is no such thing as stupid questions, Only stupid people.
if the rims are perfect u just want a color change give them a rub with some scotch brite and paint over it with a decent satin black acrylic or enamel coat should look good and last awhile for rims u should do 2-4 coats aswell![]()
A paint job is only as good as the preparation you put into it, make sure they are clean, rough the surface up with a scotch pad of some sand paper so the paint has something to stick to, give it a coat or two of primer and then paint away, take your time and add a little bit at a time, dont try and make the coats to thick to save time. Lots of thin coats with adequate drying time in between coats will yield the best results.
