Results 1 to 6 of 6
Thread: Getrag 290 gearbox on VS and VT 5.0l
    GM
    Jun 2010
    Question Getrag 290 gearbox on VS and VT 5.0l
    Hi,
    I'm curious to know the general opinion of the Getrag 290 5 speed manual gearbox that came on the VS to VT 5.0l v8's. Is this a good reliable box? I had a really quick phone chat with a conversions fella who said that it is crap but that is the first time I have heard that. They're not cheap to buy.
    And another beginner question, are the bolt patterns for transmissions on the blocks for the v6's and 5.0l v8's the same? I would have thought that they are identical, they have the same 4L60E auto box right? That same fella said that the bolt pattern is different ... I thought that there was a standard bolt pattern on those blocks. Did the bolt pattern change on the LS1s?
    Thanks and sorry for the newby questions, but I've got to start somewhere.
    VT V8 Calais
    Mar 2007
    Hey Prolepsis
    I am looking into this too. The biggest issue I have seen with these boxes is the duel mass flywheel that came from the factory. They are expensive and can't be machined. From what I have seen the boxes are quite good given that they are in good nick, but I wouldn't go putting a heap of power through it (If you start doing serious mods a t 56 would be better). Also from ads on ebay the V8 and V6 boxes are different.
    My plan is to get a kit from ebay and also get a new clutch and a aftermarket machinable flywheel, this way it will be far cheaper to maintain down the road.
    hope this helps
    50LTRv8
    keza87's Avatar
    keza87 is offline JCCC NSW Member
    VX Wagon S3.8 M5
    May 2006
    Yes the bolt patterns are different between V6 and V8. An auto V8 box will not fit a V6 and vice versa.
    You could go with the T5 box that was in ~VN-VS S1 but they have a cable clutch.
    I have the Getrag 260 in my wagon and have converted the flywheel to a solid unit and will not go back.
    People do say they cannot handle much power but I haven't had any issues with mine with a supercharger.
    JCCC NSW Member
    Check out my ride here : VX Manual Wagon with VZ Senator front end now Supercharged
    Just Commodores NSW Chapter. Join in for a cruise some time!
    Click here for more info
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    I find the T5 box is a lot better than the getrag box, along with parts being substantially cheaper with a lot more variety.
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
    VT V8 Calais
    Mar 2007
    Quote Originally Posted by keza87 View Post
    Everytime I call a wrecker they tell me a t5 will not fit a commodore that came with a getrag, is this true?
    50LTRv8
    Mar 2008
    Quote Originally Posted by 50LTRv8 View Post
    I swapped my getrag box out for a Mal Wood T5 - maybe give them a call?
  1. Removing Shifter from Getrag Gearbox
    By antelopeslr5000 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-03-2010, 08:12 PM
  2. Getrag gearbox rebuild vt v6?
    By stevoss in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-02-2010, 09:23 PM
  3. Getrag Gearbox Rebuilds?
    By social in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-01-2010, 07:23 PM
  4. VS Gearbox..... getrag or T5? which one best?
    By Jake.VScommo in forum General
    Last Post: 17-10-2009, 08:34 PM
  5. What gearbox Oil (Getrag 5sp V6)
    By buzurk in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-09-2007, 07:51 PM
