How does one change or look at, or replace the hand brake shoes I have one wheel very stiff to turn by hand any help thanks Denis
gotta pull the rear disks off.. there are handbrake shoes inside the disks... before u try pulling the disks off... back the cable off all the way cause u will bend clips and all sorta stuff if the shoe grabs on the inside of the rotor...
Thanks mate though i would ask first. What are the two rubber plugs in the drum, is that where to adjust the shoes.i
it has one shoe a side yes the plugs are meant to be adjusting holes but are shit i adjust them with disc off have you jacked it up and run the engine it might be a wheel bearing there ####s to press lucky i have the tools to do them
