Results 1 to 6 of 6
Thread: vr guards and nose on to vp ????????????? can it be done
    vp ute , aclaim vr wagon
    Aug 2010
    new zealand
    Default vr guards and nose on to vp ????????????? can it be done
    ok peoples i have VP ute an vr aclaim wagon ?? some idiot ran into back of wagon so now its bound for scrap yard BUT ??? i want to put VR guards ,, lights and bonnet and bumper on to VP heres the biggy can it be done as a straight bolt on job ??????????????????????????????????? has anyone seen or heard of it being done ??????????????????????
    cheers
    VXII Berlina 5.7L / VW Golf GTi
    Mar 2009
    South-west Sydney NSW
    I have seen it done. From memory it is a pretty easy swap over.
    There are 2 types of pedestrians, the quick and the dead
    Check out my ride here....
    http://forums.justcommodores.com.au/...rlina-ls1.html
    nemesis_adrasteia's Avatar
    nemesis_adrasteia is offline better to reign in hell
    VR accliam, TF gemini, TC gemini, 79 isuzu ute
    Feb 2009
    longford, victoria
    as far as i know the while lot swaps over
    "The mind is its own place, and in itself, can make a Heaven of Hell, a Hell of Heaven."
    apparently wasting my time with 97 cubic inches
    milk doesnt come in 1.6 litres
    my geminis
    LUMPY 8's Avatar
    LUMPY 8 is offline buddaboy1990
    VK V8 WAGS, The bannana (vp calais donor), VS BT1
    Nov 2007
    SAs biggest retirement village (victor harbor)
    yep everything swaps over no problems. Exept where the sides of the front bumper goes on because the vp has like a bit where it slides on and the vr has bolts that come up thru the bottom 2 a piece of metal that is behind the guard. The bit behing the guard can come off so its easier 2 take that off and swap it over aswell. Dont 4get 2 take the reo bar off of the vr 2 put on the vp
    Wrecking VL factory V8 only a few bits left still have full dash/crash pad
    and have a vk 202 motor and 5 speed Make an offer want it gone
    Aug 2010
    new zealand
    hey thanks all for the help yes i now know that it can be done easy //// so cheers all for the input // go buy yourself a beer on me !!!!!!!!!!!!!!!!!!!
    Quote Originally Posted by buddaboy1990 View Post
    VR V6 turbo 4speed
    Sep 2007
    coffs harbour
    my two cents too, ID try and put the VR Kframe in as well as the VR struts and all the front suspension and brakes. the vr has a wider front track so will make ur VP handle much better, however the strut tops are different, im doing the same conversion except im putting my VN adjustable strut tops into my VR so i have some castor adjustment. and so far iv discovered that the the bearing that the strut actually bolts to are slightly different sizes, and so will have to be pressed and changed over so they can bolt up.
    my reason for stating this, i tried to put some VN guards on a VR once, and the VRs wheels stood proud of the guards, and vice versa, vr guards on VN suspension, make the wheels look like theyre sunk in. its a personal taste issue i have where i like the tires to be flush with the guards....... u may not be bothered by it, but i notice things like that....
  1. My VY's Nose Job
    By Mossman in forum VY Holden Commodore (2002 - 2004)
    Last Post: 29-04-2008, 08:51 PM
  2. Replies: 16
    Last Post: 27-07-2006, 04:18 PM
  3. nose redesign
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 15-03-2006, 11:46 AM
  4. Red Nose Day Cruise NSW 26/6/04
    By Julie in forum The Pub
    Last Post: 23-06-2004, 06:20 PM
