Page 1 of 2 12 LastLast
Results 1 to 25 of 46
Thread: removing a rounded sump plug
    idb
    idb is offline
    holden vx s m5
    Nov 2008
    Default removing a rounded sump plug
    hey all i just got vx s pack and i thought i mite change its oil and i found that da old owner has rounded the sump plug. I tryed removing it with every thing i can think of but still no luck Can any one here give me some clues to removing it or is there any tools which are good at removing rounded off bolts thanks for reading this and your input idb
    VS Exec 5spd
    Aug 2008
    Rusty's Avatar
    Rusty is offline ٩(-̮̮̃•̃)۶
    304 Ute, WRX Impreza
    Mar 2010
    Queensland
    If desperate to get it off and your obviously replacing it anyway. Drill a drillbit sideways through the top of the sump and remove drill leaving the drillbit through the sump. . Then use hammer on the drillbit as leverage.
    Other option i often thought about was welding a small rod or chunk of metal onto the sump and using that as leverage. Never tested it so you'll probably blow up if you try it.
    Good luck mate
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Try using a pair of stilsons , They are a bit like an adjustable spanner .The more leveridge you use to undo the nut , the more they clamp onto it which reduces slipping off the nut and rounding it off even more.
    Lumps of cheese's Avatar
    Lumps of cheese is offline Who wants chowder?
    MY08.5 VE V8 CALAIS/2010 Hilux SR D4 Dual cab 4x4
    Boulder Crusher Champion! Balloon Park Champion! Action Fish Champion! 501 Darts Champion! Frogger Champion! Jungle Kid Champion!
    Nov 2005
    Warrnambool
    VL, VH V8 wag, Zook Vitara.
    Apr 2005
    Ardlethan, NSW
    stilsons or vicegrips...the way to go!
    Need some parts for my VH 253:
    Green standard steering wheel...Green lower B-pillar covers.
    Green sunglasses holder/lower dash bits...Air-con and assorted engine bay parts.
    PM with any info.
    VP SS
    Jan 2008
    Hiding in WA somewhere
    Quote Originally Posted by Juzo View Post
    Yep, stilsons are good. If all else fails tack weld a nut on the plug to get it off.
    +1 best options
    If its got Wheels or Boobs its gonna cost ya money
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    undersuspicion is offline Now That's How We Roll!
    Vy SV8 Series 2
    Aug 2010
    vice grips or a small socket and smash it on with a hammer.. You wont be able to use the socket again though id expect.
    VS V6 TwinTurbo/VT SS Manual
    Sep 2005
    Use a hammer and chisel, hit it anti clockwise and it will come off. Do not go hitting a drill bit with a hammer if you dont want bits of drill in you skin. Do not smash a socket on it as you will most probably crack the sump as its only think cast aluminium.
    Doubt vice grips or stillsons will get it off either. It needs a quick sharp tap to crack it.
    Just think about it. How tight is it on there if the last owner rounded the head off???? Bloody tight.
    kcpwns's Avatar
    kcpwns is offline Kicker - Livin' Loud :)
    VY V6 Equipe
    Jan 2010
    Shepparton
    i had the same problem on my vy...i found welding a nut onto the existing sump nut was the easiest way
    make sure ya dont earth out the welder near anything electronic on the car tho..
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    Quote Originally Posted by IBLOWN View Post
    It could be loose as a goose. I've seen wallies round of loose nuts by using the wrong tools. Once they're rounded they might as well be welded in though.
    idb
    idb is offline
    holden vx s m5
    Nov 2008
    Dec 2008
    You could also use a dremel or similar tool to flatten off 2 sides of it so you can get the vice grips onto it.
  15. #15
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Quote Originally Posted by maldotcom2 View Post
    Thats a good idea ,or grind the sides down so you can fit a spanner on . If the vice grips slip then your back where you started
  16. #16
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Vice grips or Stilsons would be just about guarenteed to work, it can't be THAT tight or it would have just stripped the thread.
  17. #17
    1998 Mercedes Vito 113
    Oct 2009
    S.E VIC
    ^ In which case you'd need to re-tap the thread also =\...
    But yeah, vice grips~!
    Quote Originally Posted by perkoracin
    it like u pull at to a red light and they go o its that fag from just Commodores and it like u go tohe drags and ur car runs a like a 9 sec run as a eg and theres run a low 14 um i would Lol so hard like Epicly and then call them The Internet Mouthers and no go Lol thats a eg they might have Fast as rides 2 but may not sound as a Nice small block chevy with a Supercharger on it lol.
    Click here for my old VY Commodore!
  18. #18
    Swordsy's Avatar
    Swordsy is offline mmmm beer....
    VUII Maloo R8 - XJR1200 - XR450R
    Nov 2007
    Newi NSW
    Vice grips slip and you bash your hand. Stilsons are the way to go.
    Quote Originally Posted by STEALTHY™ View Post
    Public Service Announcement.
    Those members who do not hold a 'sense of humour' should not venture into the 'jokes/humour' section.
  19. #19
    VzVzVz's Avatar
    VzVzVz is offline <<< My Ride
    VZ S ute
    Jun 2009
    Port Melbourne
    get the smaller size down socket and hammer it on. Or use a single hex socket of the same size instead. If that fails, use a pair of vicegrips and squeeze the tits off the c*nt.
  20. #20
    Commydoor's Avatar
    Commydoor is offline born in the FB era
    Vr Ss Blown
    Sep 2007
    Beresfield, NSW.
  21. #21
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Grip-all-####-all's FTW!
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
  22. #22
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
  23. #23
    ClairBear's Avatar
    ClairBear is offline Make the stupid stop!
    VE Omega / Hyundai Getz
    Nov 2003
    SA - The Murder State
    When this happened to me I put her up on the hoist, for better leverage, then bashed a smaller ring spanner onto the plug and got it off that way. Ensure you buy a new sump plug first though lol.
    Quote Originally Posted by commodore1310 View Post
    Ok, once again ive run aground with a bunch of elitist PRATS who think they know it all, stuff your cars and stuff your forum!
    Quote Originally Posted by one_and_only2004 View Post
    No, driving a v6 engages GOD MODE. Please don't continue the argument...
  24. #24
    Sep 2005
  25. #25
    VKCOMMO's Avatar
    VKCOMMO is offline Carpark Mechanic.....
    Aug 2009
    Springwood, NSW
    DO it haydz style and bash a socket onto it.
    Or do what me and a few mechanics once did and weld another bolt onto the sump plug, But we did it with a diff sump plug...
    [09-01, 22:47] HoZy: VKC doesnt finger, He fists... Because Ranga
  1. sump plug!
    By VsAcclaim1312 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-02-2010, 10:35 PM
  2. vz sump plug
    By nuradh in forum General
    Last Post: 08-12-2009, 01:09 AM
  3. where is VT sump plug
    By markcorinna in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-10-2008, 10:54 AM
  4. Removing Rounded Bolts
    By fitzy2005 in forum General
    Last Post: 26-10-2006, 07:34 PM
  5. Removing stuck sump plug.
    By Uber_Matt in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-03-2006, 09:14 AM
