Results 1 to 5 of 5
Thread: is this to good to be true
    vr1uz-fe is offline Banned
    vr berlina
    Aug 2010
    australia
    Default is this to good to be true
    Holden Commodore T3T4 Turbo Charger Kit: eBay Motors (item 270621283614 end time Oct-11-10 10:11:19 PDT)
    i was thinking there has to be something wrong here if not ill be buying this
    vr berlina
    Aug 2010
    australia
    it's just that i have writen up a list of parts for a turbo system im at 6000 with out any engine mods just turbo and fuel system havent even got to the oil system yet
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    You generally get what you pay for mate.
    That said, if you bought it and half of it was crap. You still win.
    vr berlina
    Aug 2010
    australia
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
    I guess it really depends on how much you're willing to spend etc - but generally you'll find there's a few rules that ring true (from my experiences anyway)
    1) the poor man pays twice
    - i.e. if your wastegate diaphragm burns up or cracks due to cheap manufacturing/materials etc, you'll be buying a new (and probably better quality wastegate)... paying again.
    2) you get what you pay for..
    - a turbo costs a bit of money to manufacture due to particular materials being used, and processes of manufacture to ensure that housings don't crack, use of lightweight materials on the wheels etc to reduce rotational mass so they spool decently etc. etc etc. - Granted, when you buy a "brand name" turbo there is clearly more of a markup due to the brand name - but you do get a higher quality product that will perform better. - where's all the 10 second cars with $500 generic ebay turbos?
    I've bought a few "cheapo ebay" components in the past for various projects that I've wanted to do on the cheap. Generally I've found that they perform as expected considering the price. - generally things don't fit together too well, threads are rough, materials are cheap/borderline unsuitable for their intended purpose.... hoses/lines fall apart quickly... etc etc
    Having said all that - there's not much that can go wrong with intercooler pipe... or various other simple items.
    Also, if you were to buy all that stuff separate, you'd obviously pay more - but you don't need/want half that stuff anyway
    Your estimate of 6k sounds about right for a decent turbo setup on a v6... depending on how much you can do yourself. I'd work it out like this:
    - manifolds & dump pipe welding + connection - $1k
    - 2nd hand xr6 turbo turbo... (good for 300+kw) .. internally gated etc - $1k
    - good quality simple boost controller - $50
    - oil and water lines, fittings, welding of sump - $150
    - intercooler, piping, clamps joins etc - $700
    - bosch 044 fuel pump, surge tank, lines etc - $350
    - re-drilled ls1 injectors - $200
    - 2 bar map sensor - $150
    - tune - $1000
    Total of around $4600 for a good package. (add another 1500 on top of that for all the "little things") - that has potential to crack the 300rwkw mark... if you're willing to push it
  1. Replies: 12
    Last Post: 02-08-2009, 09:59 PM
  2. Almost too good to be true
    By MEANVY in forum The Pub
    Last Post: 28-10-2008, 11:29 AM
  3. Too good to be true
    By Reaper in forum V8 Development and Modification
    Last Post: 13-10-2008, 09:24 PM
  4. if it sounds too good to be true then it probably is
    By webwombat in forum VY Holden Commodore (2002 - 2004)
    Last Post: 15-02-2007, 08:44 PM
  5. are these wheels to good to be true?
    By pepsi in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-02-2007, 09:26 PM
